Author Topic: My Magic Pie II (Generates Power) Without Battery!!!  (Read 26998 times)
Offline MagneticMotorE
« on: August 25, 2011, 06:51:42 AM »
First off! I do not have a battery yet!!!
When I reach about 7 mph or more from Pedaling, the battery power indicator lights work, Regenerative Brakes Work & Horn Works... Why is this?
« Last Edit: August 25, 2011, 09:38:43 PM by spellchecker »
Re: My Magic Pie II (Generates Power) Without Battery!!!
« Reply #1 on: August 25, 2011, 11:23:29 AM »
Most permanent magnet motors will also work as a generator and start producing a voltage which will get higher as their driven speed increases.
Although this is great for regenerative braking, it unfortunately produces unwanted drag when the motor is not being used, which makes it harder to pedal.
It works pretty much like a standard hub dynamo:
But the Magic Pie is much bigger and can therefore generate a lot more power!
This might also explain why it causes the extra drag.  ;)
« Last Edit: July 05, 2017, 06:23:42 PM by Bikemad »
« Reply #2 on: August 25, 2011, 05:52:01 PM »
 :D. Again... Truly helpful. Thanks!
« Last Edit: August 25, 2011, 09:36:52 PM by spellchecker »
Offline krilson
« Reply #3 on: September 16, 2011, 04:58:56 PM »
Don't run this thing without a battery or with the battery turned off. GM claims to have freewheeling diodes and I'm sure they do, but if you are generating 10 volts through zero to.01 ohms, then you could potentially have catastrophic failure.
The voltage constant is voltage produced / rpm, usually given as volts per rpm and maximum rpm will happen when applied voltage equals generated voltage
Offline mike662
« Reply #4 on: September 20, 2011, 06:48:43 PM »
I made an interesting observation while riding my 1000W rear hub a few days ago. I was riding without my battery attached and was playing with the reverse button (red button on the twist throttle). When I pushed the button in and then back out, all 3 lights on the throttle battery indicator lit up and the horn works as well. Somehow, doing this allowed the controller to receive power? I could also tell that there was a slight load on the wheel. Here is a test I just did: http://www.youtube.com/watch?v=8y94iF8aFhc
