Author Topic: No current flow  (Read 22477 times)
Offline Bingo
No current flow
« on: August 03, 2011, 01:08:03 AM »
48 volt battery pack charges until charger shows green light
battery pack only checks 44 volts after charging
When this battery is connected to ammeter with a 20 ohm piece of resistance wire, there is only 10mA current flowing. Even if battery is under charged, current should be more than 2 amps.
What gives?
Bingo S. Noon
Re: No current flow
« Reply #1 on: August 03, 2011, 01:46:11 PM »
Hi Bingo andto the forum.
44V is much too low for a fully charged 48V pack, it should be around 54.6V.
Check to see if your charger has a voltage switch to select your mains supply voltage.
There might be a simple slide switch like this:
If your charger is fitted with one, set it to the 110V setting (if applicable) by using a small screwdriver or cocktail stick etc. to slide it to the correct position.
Let us know if this rectifies your problem.
Offline Bingo
Re: No current flow
« Reply #2 on: August 03, 2011, 03:47:58 PM »
Thank you for the tip about the switch, I am aware of that.
However, the fact that a battery, at any voltage, should be able to supply more than 10mA when shunted thru a resistance and an ammeter.
