Author Topic: This may help any one buying BLT 500w to 800w Tricycle Motors  (Read 43519 times)
Offline Who42
  • ELECTRIC BIKE NUT
    • PLUG IN CARS & BIKES
This may help any one buying BLT 500w to 800w Tricycle Motors , Thay come with a none standed Bicycle sprocket 420  1/2"  5/16"  1/4" 0.227" which is 1/16" wider  so you will need 420 chain
Torque or load is this same as bicycle chain at 810 lbs but wider roller means less wear  ???
Bicycle and Motorcycle Chain Dimensions Guide  ;D
Chain No. Pitch Roller Diameter Roller Width Sprocket thickness
                                         Chain No. Pitch / Roller Diameter / Roller Width Sprocket thickness
Bicycle Chain, with Derailleur           40   1/2"        5/16"              1/8" 0.110"
Bicycle Chain, without Derailleur       40   1/2"        5/16"            3/32" 0.184"
Bicycle Chain, Asian Tricycle           420  1/2"        5/16"              1/4" 0.227"
Bicycle Chain, H/D Asian Tricycle     425  1/2"        5/16"             5/16" 0.284"
Motorcycle  Chain,                        428  1/2"        5/16"            5/16" 0.284"
Motorcycle  Chain,                        520  5/8"       0.400"             1/4" 0.227"
Motorcycle  Chain,                        528  5/8"       0.400"            5/16" 0.284"
Motorcycle  Chain,                        530  5/8"       0.400"             3/8" 0.343"
Motorcycle  Chain,                        630  3/4"       15/32"             3/8" 0.343"
ANSI Standard Chain Dimensions  8)
Chain No. Pitch    Roller Diameter Roller    Width Sprocket thickness     Working Load
        25   1/4"             0.130"                  1/8" 0.110"                          140 lbs
        35   3/8"             0.200"                  3/16" 0.168"                         480 lbs
        40   1/2"             5/16"                    1/8" 0.110"                          810 lbs
        40   1/2"             5/16"                    3/32" 0.184"                        810 lbs
        40   1/2"             5/16"                   5/16" 0.284"                         810 lbs
        41   1/2"             0.306"                  1/4" 0.227"                          500 lbs
        50   5/8"             0.400"                  3/8" 0.343"                         1400 lbs
        60   3/4"             15/32"                  1/2" 0.459"                         1950 lbs
        80    1"                5/8"                    5/8" 0.575"                         3300 lbs
ELECTRIC BIKE NUT
