Author Topic: wire set for Magic Pie controller  (Read 29229 times)
Offline chris1
« on: June 12, 2011, 09:25:11 PM »
Hello,
i have a question:
my wire set for Magic Pie controller has a capacitor in the battery wire connector G.
is this a capacitor or varistor ?! and what is this for a value?
this component is broken, I need a new component.
thank you for your help
chris
Re: wire set for Magic Pie controller
« Reply #1 on: June 13, 2011, 09:17:54 AM »
Hi Chris, this is in your battery cable?
Is there any chance you can take a photo? That would be good
Cheers
« Reply #2 on: June 13, 2011, 10:24:17 AM »
I wonder if GM have fitted something that works as a pre-charge device to eliminate the big spark on initial battery connection, as I have not seen anything fitted into that particular lead (apart from a switch to operate the anti-theft function on earlier controllers).
There used to be just a piece of wire looped across from the battery positive connection to the "d" terminal.
A picture would certainly be helpful.
Offline chris1
« Reply #3 on: June 13, 2011, 11:04:18 AM »
here is the photo........i hope....  :-\
http://imageshack.us/photo/my-images/191/bild022vw.jpg/
labelprint  72  XF050 and under page  PGGA China
« Reply #4 on: June 13, 2011, 02:21:02 PM »
Chris, that component appears to be an "overcurrent protection device" to limit the current to 40Amps max.
Resettable Fuses Raychem Circuit Protection products. Also known as PPTC or Polymer Positive Temperature Coefficient, resettable fuse come in radial, axial or surface mount packages. Key benefits are obviously, the self-resetting function which makes the device transparent to the user as there is no need for replacement. It reduces warranty and service cost and is ideal for remote applications. Key applications include telecom, battery, computing, consumer and medical
The RXEF050 is a radial resettable fuse with a working voltage of 72 VDC. It comes in bulk packaging and operates at 40 amps
If you try a Google search for RXEF050 72 you should be able to find a suitable replacement.
I have attached a screen shot of a datasheet I found with more details below.
« Last Edit: June 13, 2011, 02:22:50 PM by Bikemad »
Offline chris1
« Reply #5 on: June 13, 2011, 03:16:09 PM »
Hello Alan,
thank you very much for your information !!!!!
best regards
chris
« Reply #6 on: June 14, 2011, 02:04:14 AM »
This is something I have not seen before. I just received a sea order a few days back and will look at my new controllers to see what the wires look like. Ill get back to you with pictures.
« Reply #7 on: June 15, 2011, 03:08:42 AM »
Well I looked in a box of new controllers, opened a MP2 external kit, a 901 and a 902 kit. None of the controllers had any capacitor added to the wiring. Everything looks normal.
