Author Topic: PAS  (Read 22807 times)
Offline karen
PAS
« on: June 04, 2011, 10:50:04 AM »
I have a joy e-bike with a Magic Pie fitted.... it also has PAS, but I still havent found out how this PAS works.... Since I have 48V battery, it would be nice if the police had to do more... they can just turn the throttle to see that its totally illegal here... live in Norway, 250W, 25km/h and PAS is the limit....How to quicly disable the throttle is what I need to have done....
« Last Edit: June 04, 2011, 10:53:02 AM by karen »
Re: PAS
« Reply #1 on: June 04, 2011, 12:07:13 PM »
fit a switch on the white wire coming from the throttle, and use a 12k resistor across the switch , that way, the pie will still see a 1v throttle, but it wont work if used.......
« Last Edit: June 04, 2011, 12:54:14 PM by Bikemad »
Offline karen
Re: PAS
« Reply #2 on: June 06, 2011, 03:06:53 PM »
Nice! Just what I needed!  ;D Thank you so much:)
Re: PAS
« Reply #3 on: June 16, 2011, 08:11:01 AM »
Thanks alan, I knew I couldnt have been organised enough to put a picure in :)
