Author Topic: Programming MP internal controller  (Read 23393 times)
Offline suprted1
« on: May 26, 2011, 12:49:10 PM »
I find a lot of people have the same problem as I, but I cant find a solution.
When I connect the USB cable, I get the message, "connect succesful" (and the controller starts beeping once every second, approximately) and when I push the "Disconnect" button, I get the message "get config succesful"
No success when programming and saving information. I received this MP 2 days ago, and believe that the programming should work. Also I have checked that the cable is properly connected, checked the wires, anything I can imagine.
Please help, I would really like to have this working by the day.
Best regards, Arnfinn
Suprted1
26" Rear MPII, 14/15S LiPo, but I need to fix several spokes after the first testride of 20-30Km. Topspeed 50kh/h 35-40 on flat road, I neeeeed more :):)
Offline Cornelius
  • Grimstad, Norway
Re: Programming MP internal controller
« Reply #1 on: May 26, 2011, 02:12:04 PM »
I'm one of that lot! ;D
Offline SydneyCommuter
« Reply #2 on: May 27, 2011, 07:20:16 AM »
When I set up on my WinXP Laptop, HID usb driver loaded, rebooted.
The program is giving the same as you describe, constant beeping, it sometimes appears to return the config which is the default 24V 30/50amps.
This current config I suspect is causing my BMS to cut power intermittently on takeoff.
Most frustrating.
