Author Topic: thread size information please  (Read 115507 times)
Offline wattsup
« on: May 21, 2011, 09:06:37 PM »
hi, does anyone know the thread size of the majic pie 1000w 48 v axle shaft, and is it metric, imperial or chinese, the nuts supplied with mine wobble on the thread of shaft and I want to replace them with a better fit if possible, as they do not inspire confidence to stay tight
read twice,write once.
Re: thread size information please
« Reply #1 on: May 21, 2011, 09:11:32 PM »
send a pm to webby, he got some replacement nuts recently , should be able to help  ;D
« Reply #2 on: May 21, 2011, 09:12:10 PM »
I'm pretty sure they are M14 x 1.5mm, but I could not find stainless domed nuts in that size to fit mine.
Offline wattsup
« Reply #3 on: May 21, 2011, 09:20:42 PM »
thanks, as usual this forum comes up trumps on helpfullness, cheers guys !
Offline Eriknoort
« Reply #4 on: May 22, 2011, 09:02:48 AM »
Hi wattsup,
Try the local car-tyre shop.
I got my extra nuts there for free. :D
Usualy they got a box with all kinds of bolts and nuts.
14x1.5 is the size.
Erik
Offline Webby
« Reply #5 on: May 22, 2011, 10:59:28 AM »
Hello Mate
I think they are 14mm (locking nuts)   but I took the old one with me when I went to the merchants near where I live and he got the right ones for me.
I'm happy to post you my 2 spare that I have if you like? There only a few pence each so don't need to worry about money or anything. I not back to the UK until Tues evening 24th May.
When I get some more next time I will remember what size he said.
Anyway let me know if you want mine.
Webby
Offline wattsup
« Reply #6 on: May 22, 2011, 04:12:45 PM »
thanks for the offer webby but no need bud, as i,ve already bought some from fleabay. my next challenge are the torque arms and some soldering, as i,ve shortened and tried to tidy my wiring. I will post pictures of my build. thanks again all.
Offline wattsup
« Reply #7 on: May 27, 2011, 11:15:43 AM »
the thread size is NOT 14mm 1.5mm pitch, it is; 14MM X 1.25MM METRIC FINE
« Reply #8 on: May 27, 2011, 12:22:14 PM »
You must have a different axle to mine, as my Magic Pie is definitely M14 x 1.5mm, I couldn't lay my hands on my pitch gauge so I set my vernier gauge at 15mm and it lined up across the top of ten threads exactly (1.5mm pitch)!
M14 x 1.0mm, M14 x 1.25mm and M14 x 1.5mm are all referred to as as metric fine, whereas M14 x 2.0 mm is metric coarse.
If you could measure across the top of ten threads, you should be able to confirm whether it's 12.5mm or 15mm.
Offline wattsup
« Reply #9 on: May 27, 2011, 01:06:40 PM »
could not do it with vernier, about 13mm across 10
Offline wattsup
« Reply #10 on: May 27, 2011, 01:17:44 PM »
i bought some 1.5 pitch nuts and they would not screw on to 1 thread even. webby sent his spare ones to me as I pm, ed him , they screw right on good without wobbles
« Reply #11 on: May 27, 2011, 03:33:39 PM »
I've checked again, and the only details I could find from GM relating to axle threads was for the HBS hubs, which are clearly marked as being M14 x 1.5mm.
(see attachment)
From your measurements, it would appear that they have changed to a finer pitch on some axles.
Offline wattsup
« Reply #12 on: May 27, 2011, 06:17:41 PM »
my motor, 1000w 48v majic pie external controller, was purchased,26/04/2011. the m14 part is correct, but not 1.5mm, because as mentioned, this pitch wont screw on 1 thread. it appears that you may be correct about thread change. anyway my problem is now solved to a satisfactory conclusion, thanks alan.
« Reply #13 on: May 27, 2011, 08:01:28 PM »
I've had this problem too. I bought some M14 1.5 'half nuts' and they didn't fit. I've just been too embarressed to mention it  'cause I thought you all might laugh at me :-[
« Last Edit: May 27, 2011, 08:55:57 PM by Andrew »
Offline wattsup
« Reply #14 on: May 27, 2011, 08:17:59 PM »
dear andrew, don,t you feel like a great weight has been lifted off your shoulders! coming out like you have, it must have been difficult living with the burden, and I feel for you. bet you feel great now.......feel the love ;)
