Author Topic: My turn to complain about USB cable...  (Read 54188 times)
Offline SydneyCommuter
Re: My turn to complain about USB cable...
« Reply #15 on: May 27, 2011, 07:35:38 AM »
Your UTube clip is identical to my issue also.
« Reply #16 on: May 28, 2011, 04:55:58 AM »
Same
HID Drive loaded ok, on connection to the pc (vista) pc recognises the cable and driver ok.
Program starts, hit connect and its beep once a sec.
This has to be an issue between the PC program and the controller something has changed and the change has not been managed or reflected in either the program of the controller.
This must be an issue for MP support guys??
cheers
Offline csm
« Reply #17 on: May 19, 2012, 12:54:41 AM »
Does the usb cable for the Magic Pie internal use 3 or 4 wires? (+, -, data; or +, -, send, recv.?)
If it uses 3, I'm guessing the cable are an usb-i2c converter; if 4, then usb-rs232...
Here is a picture of the inside of the Magic Pie II USB cable. It looks like 4 wires connected to the board.
