Author Topic: My regen controller died  (Read 23657 times)
Offline glenn
« on: August 21, 2008, 09:58:36 PM »
i have an 800watt hub motor connected to the 48v 1000w regen controller and it worked great for about 100 miles.  today everything shut down.
when I plug in the battery it acts as though there is not a complete circuit.
I do have a cycle analyst plugged in line between batt and controller which I will remove tonight.
the rear wheel is hard to turn even though the battery is disconnected ( just like when it is in regen mode )  usually the wheel spins free when the battery is disconnected.
Any suggestions would be apperciated...
gp
Offline glenn
Re: My regen controller died
« Reply #1 on: August 22, 2008, 05:01:04 PM »
I'll answer this myself:
I had a full lipo battery and went down a steep hill in regen mode.
The regen tried to put power back in the battery, the battery didn't want it and something had to go.
This damaged my controller and battery.
Anybody know how to prevent this??
Full Answer from electronic engineer:
Motors that have their windings shorted together turn hard.  That's what dynamic braking does, essentially.  So maybe your controller is shorted.
Another thing is that whenever power MOSFETs fail due to overheating and/or voltage spikes, they very often fail shorted.
A + B = check to see if the motor turns easily when it's unplugged from the controller.  If so, the motor's probably fine.
If the controller is bad, it's probably the power MOSFETs.  Rip it open, and trace the motor power wires through case, connector, circuit board, etc., up to the big chips with heatsinks.   Find the part number and search the web for data sheets and distributors.  Try http://digikey.com/ for both.  If you can find replacements and data, then it MIGHT be worth going forward.  See attached datasheets as examples.
See attached Application Note, and refer to Figure 2.  The power chips may be electrically arranged as three groups of two.  Three will be connected to the (+) rail, and three will be connected to the (-) rail.  Each pair will be connected together, and that connection will go to a motor wire.  For more info, that App note came from
    http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1523
Once you have figured out your layout, measure the resistance across similar pins of similarly connected MOSFETs.   If they are not the same, you found a problem.  The question is how to solve it.  There may be other things wrong besides the shorted MOSFETs.  I am not familiar with the regenerating drives yet, but I expect that the basic circuit is the same with extra stuff to boost the back EMF above battery voltage.
