Author Topic: Battery Anderson connector in 8 pieces  (Read 29480 times)
Offline Rodmiami
« on: April 23, 2011, 05:00:03 PM »
  Gary or BikeMad , I was looking for a bad connection ,since my green light goes out on acceleration .While cleaning the connectors on the battery one of the connectors slid into the battery , then pieces of the black plastic started to fall out . I opened the battery and both connectors fell out and 8 pieces of plastic , The Anderson connector , fell out . I am just going to solder a pigtail on . My question is since I am not sure if the wires switched possion when I took it apart , Does the Ground wire go thru the switch and the hot is coming from the right side in the battery , I don't want to screw it up . Thanks Rodmiami
Offline Rodmiami
Re: Battery Anderson connector in 8 pieces
« Reply #1 on: April 23, 2011, 06:05:34 PM »
  I have the battery upside down , I think the plus + side is on the left side of battery coming from the front and the Ground - is open and closed by the switch . Can anyone conferm this ? Thanks Rodmiami
Offline Rodmiami
« Reply #2 on: April 23, 2011, 07:19:38 PM »
  Never mind I am done.
« Reply #3 on: April 23, 2011, 08:36:18 PM »
A running commentary  :D
glad you sorted it :)
« Reply #4 on: April 24, 2011, 02:18:52 AM »
Sorry for the late reply but if you had a meter is easily sorted out. Glad you figured it out anyway :)
