Author Topic: one GM brake lever to two external controllers for motor cut-off  (Read 32802 times)
 How easy is it to wire GM brakes to both controllers in order that both motors cut out when only one brake lever is pulled. I'm sure it's easy but I don't(as yet) have the parts in front of me to work it out!
  Is there a diagram? :)
Re: one GM brake lever to two external controllers for motor cut-off
« Reply #1 on: April 21, 2011, 04:34:11 PM »
I just wired the wiring from the brakes, and connected with both sets of brake wires from the controller, worked fine :D
Offline krelle52
« Reply #2 on: April 21, 2011, 04:41:44 PM »
Hi andrew
First I thought it was easy, but now I'm slightly in doubt about the need for the brake to be connected to z terminal on both controller. I made a quick diagram. This is my suggestion and I'm pretty sure it's right. But I would like a second opinion!
/ Krelle52
Offline krelle52
« Reply #3 on: April 21, 2011, 04:59:57 PM »
There was someone faster than me. :)
« Reply #4 on: April 21, 2011, 05:05:53 PM »
ha ha :D.   thanks both. once I have the bits in front of me I know it will be straight forward
