Author Topic: Cruise controller cuts out on bumps?  (Read 29093 times)
Offline markaus
« on: April 08, 2011, 01:19:41 AM »
Just getting started with ebikes and really enjoying it as a transport option.
However, the roads around here are not pristine and I am finding that the cruise controller cuts out fairly often.
I have modified the battery housing so that it is cushioned more from vibration and bumps and the problem persists.
I guess its a controller issue. Any suggestions appreciated.
Re: Cruise controller cuts out on bumps?
« Reply #1 on: April 08, 2011, 02:16:17 AM »
I would be having a close look at the wiring mate, and check all of the pins in the plugs and sockets to make sure they have contact
Continuity with a multimeter will be worth the time
cheers
Offline markaus
« Reply #2 on: April 08, 2011, 02:42:24 AM »
Thanks for the tip. I will look into it further and let you know.
Offline markaus
« Reply #3 on: April 08, 2011, 05:45:02 AM »
You are magic, monkey! Checked all connections, made sure they were snug, and voila, problem solved.
cheers big ears...
« Reply #4 on: April 08, 2011, 06:29:08 AM »
cheers big ears...
No wukkas mate I see you are too an Aussie bloke?
Therefore you will not take offense when I say "No worries f$%& nose!"
Also, do not try to add tomato sauce to your pie like I did. Boy was that a messy mistake !
:D
