Author Topic: Maximun MP Power???  (Read 27418 times)
Offline _GonZo_
    • www.evovelo.com
Maximun MP Power???
« on: March 25, 2011, 10:43:50 PM »
Well another question...
What is the maximum continuous power that can be get from a MP with out smoking it?
Offline _GonZo_
    • www.evovelo.com
Re: Maximun MP Power???
« Reply #1 on: March 27, 2011, 08:29:03 PM »
So I assume that none have explored the limits...
As per the GM web it is 1000W, the problem I see is then limited by the GM controllers to 500 to 700W input continuos power that may be around 350 to 525W axle power assuming around 70% efficiency system.
The thing is after heavy use does the motor heat up at that rates?
« Reply #2 on: March 28, 2011, 06:07:07 AM »
HI Gonzo...
No warranty implied,so don't blame me :) but ive been putting 2000W through it upa hill, no peddaling, about 2 minutes ,, got a little warm, but as for continuous operating power, will have to test a lot more
Offline _GonZo_
    • www.evovelo.com
« Reply #3 on: March 28, 2011, 09:57:57 PM »
Thank you, that is a good start.
2 minutes at 2000W and only warm says that at least it can work at around 1200-1500W continuos.
At what voltage were you working the MP at that moments?
Offline _GonZo_
    • www.evovelo.com
« Reply #4 on: March 28, 2011, 10:03:52 PM »
I just relised that you have open another post around this issue, so I think better we move the discussion there....
