Author Topic: ignition key wiring  (Read 22887 times)
ignition key wiring
« on: March 25, 2011, 07:31:46 AM »
I'd rather be safe than sorry, so it's always best to check........  :-\
Can I just have confirmed that the short wire is to battery and long wire to controller. Obviously I will be changing the connector size
Offline Cornelius
  • Grimstad, Norway
Re: ignition key wiring
« Reply #1 on: March 25, 2011, 11:21:06 AM »
I would say: yes. :)
Is this a new one from GM?
« Reply #2 on: March 25, 2011, 03:41:59 PM »
Hey champ
It doesn't matter, it looks to just switch the positive feed so anyway round will work.
Is this for the new or old build?
:D
« Reply #3 on: March 25, 2011, 06:42:07 PM »
Hi cornelius, not from GM. I think it is a Crytalite product, it came with a battery bag I just purchased.
Monkey,  yep, for the new build ;D    hopefully for dual mini's ;).    the ignition key could make things a little more convenient.   I'm just a bit apprehensive at present on buying a dual mini kit until it has been tried and test with possible amp limits.   The battery I have is a 54v 16ah lithium ion pack
