Author Topic: 48v regen braking controller  (Read 28388 times)
Offline glenn
« on: July 29, 2008, 10:31:05 PM »
I hooked up the 48v regen controller to an 800w hub motor on a big skate board and it works great.  12 miles at 20mph on hilly terrain.
How do I change the cutoffs?  If I accelerate to hard it cuts out.
It says you can adjust settings with a usb connector but I have no documentation...
Offline biohazardman
Re: 48v regen braking controller
« Reply #1 on: July 30, 2008, 05:21:41 AM »
The usual problem with cut out is the batteries cannot keep up with the current draw of the motor load.   I read in an earlier thread that a programming box will be out soon for these controllers expect that is the USB you speak of.
