Author Topic: TRIKE BIKE PROJECT  (Read 96375 times)
Offline Who42
  • ELECTRIC BIKE NUT
    • PLUG IN CARS & BIKES
TRIKE BIKE PROJECT
« on: March 08, 2011, 02:48:38 PM »
TRIKE BIKE PROJECT
Using the new 48v BLT-800 BLDC motor
 How much are the BLDC motors for Trikes
48v BLT-500 ,
48v BLT-650
48v BLT-800
Will they do Regerative braking with cruise controler!!
I want to be one of the first to build a Trike with the
48v BLT-800 motor
« Last Edit: March 08, 2011, 02:53:19 PM by Who42 »
ELECTRIC BIKE NUT
Re: TRIKE BIKE PROJECT
« Reply #1 on: March 08, 2011, 05:20:53 PM »
Wow some spontaneous new projects coming out of you Who!
Can I ask how much you picked up a tricycle in Qld for?
Offline Who42
  • ELECTRIC BIKE NUT
« Reply #2 on: March 08, 2011, 08:52:58 PM »
$399
ELECTRIC BIKE NUT
« Reply #3 on: March 09, 2011, 06:48:40 AM »
Thats pretty good, any links?
I already picture this sign on the back if I build one lol
Offline Who42
  • ELECTRIC BIKE NUT
« Reply #4 on: March 09, 2011, 08:57:19 AM »
Thats pretty good, any links?   http://www.trike-bike.com.au/
  Tri DRIVE LOL   Three 48v Magic Pie's LOL ::) or Quad Drive LOL
« Last Edit: March 09, 2011, 09:07:49 AM by Who42 »
ELECTRIC BIKE NUT
« Reply #5 on: March 09, 2011, 10:51:34 AM »
That's good you posted those pics, especially the second one, hehe wow that would be fun to ride :D
The second picture looks like the axle can be somewhat customised, I have a couple of hub motors that you can modify it.
It doesn't look like you can with the GM wheels? I'm really not sure if the axle can be changed..
If I did build the trike it would be a font cast wheel, then probably a HPM5000 (or 2 lol) on the rear as the rims would be taking a beating around the bush tracks near me
Did you have any more info on the trike? Like brand/company etc. and where did you find that second picture haha
Offline Who42
  • ELECTRIC BIKE NUT
« Reply #6 on: March 09, 2011, 10:56:57 AM »
The hub motors on the Quad are normal ones just with the solid side of the axial cut off
and bolted only on one side through a 4mm steel plate the axial is minimum 10mm thick across te flats which even with the hole for the wires seems strong enough with the added tight fitting bush around the thicker part of the axial at 14mm whitch takes most of the verticle load ::)
« Last Edit: March 09, 2011, 02:08:51 PM by Who42 »
ELECTRIC BIKE NUT
Offline _GonZo_
    • www.evovelo.com
« Reply #7 on: March 09, 2011, 10:03:46 PM »
Thank you for posting that plan of the one side wheel attachment. It is one of the modifications I need to make to the MP.
If you have more information or pictures I will appreciate a lot if you can show me them. Thank you
Offline CarlT
« Reply #8 on: September 22, 2011, 05:47:34 PM »
I like that 4-wheel version. I think the 3-wheel would be fun too. I'm  guessing the 4-wheel would be more stable. It would make a good bike for someone with a disability. I wonder if it would fit on a normal wheelchair lift or if it could be modified?
« Last Edit: October 04, 2011, 11:15:57 PM by CarlT »
Carl
