Author Topic: Wiring Infinenon Based 35 Amp Controller to MP  (Read 36480 times)
Offline T5T
« on: March 01, 2011, 08:37:27 PM »
I was wondering if anyone has an idea on how to connect Infineon type controller to Magic Pie.
Have removed the internal controller and put up new cables.
Especially interesting is the throttle link.
Type controller is C3635-NC purchased from www.ebikes.ca
Re: Wiring Infinenon Based 35 Amp Controller to MP
« Reply #1 on: March 02, 2011, 04:07:58 AM »
Ermmm someone just posted a topic on this.
Generally you find the answer a bit quicker when you do a search (hint hint) ;)
Like this thread
Offline T5T
« Reply #2 on: March 02, 2011, 02:34:40 PM »
Thanks for the hint MM
Did the cable swap colors of phase wires -no effect just clicking sound when controller was activated.
But I got it to work with this way of connecting:
Mp phase wires: same as controller     y to y / b to b / g to gFrom the throttle to controller: white goes to green / black to black / red to red ;D ;D ;D ;D ;D ;D
« Last Edit: March 02, 2011, 02:43:40 PM by T5T »
« Reply #3 on: March 02, 2011, 03:32:55 PM »
Judging by the big grins your bike is all go?
What kind of improvement do you feel the external controller made?
:D :D :D :D :D
Offline T5T
« Reply #4 on: March 02, 2011, 04:32:52 PM »
MM
Would not say there are some extreme difference compared to when the internal controller was used, but what I really hope happens is that I can trust that the engine can operate over time.
Not like it was, with the hopeless gm internal controller that works only every second day and suddenly totally dead.
And if you try to buy a new internal controller from gm (Tom) the only thing you hear I "sound of silence"
Then I turn to other options (Infineon), for example, and GM loses sales.
So I do not understand why there is so little understanding of business in China.
I have 3 mp`s which I have rewired this is the first to be tested after modification.
(28 "wheel)
The next one is a "Monkey Magic Turbo wheel" Just Joking  ;D (20 "cast)
and one mp not mounted in a rim yet.
 Other informationIf anyone wonders whether the rotor inside a cast fit into a non cast mp, yes it snaps right in, just exchange free wheel cover
(the mp cast cover is little bigger in outside diameter)
« Last Edit: March 02, 2011, 04:47:00 PM by T5T »
« Reply #5 on: March 02, 2011, 10:03:56 PM »
so no extra "50% extra torque" from the 20 amps plus that can go to the wheel ?
regards
Offline T5T
« Reply #6 on: March 02, 2011, 10:21:14 PM »
dirtyginge
50% extra Torq - no not at all - I would guess about 10% more.
Before the internal controller died, it was very strong, with very good Torq.
« Reply #7 on: March 03, 2011, 04:21:00 AM »
WOW
You could make a dual drive and have a turbo trailer :D
I'm pleased you have a cast wheel, I have not turned back since I started out with a 16", now the 20's was a move that I nowhere near regret. They are a really good wheel !
Will be good to see what you do with your inventory you have now ;)
Cheers
