Author Topic: Rear Mini Motor in 135mm dropouts?  (Read 56396 times)
Offline philf
« on: September 15, 2010, 11:14:41 AM »
Of the three four GM motors I have, one is a GM rear mini motor that was purchased some time ago.  The thing is WAYYYY wider than will fit in 135mm dropouts, so I did a bend/offset job on a steel framed bike to make it work.
The engineering drawing of the CURRENT GM rear mini motor suggests that it DOES fit into 135mm - and would even suggest it's possible to bolt on a disc rotor!  Is this true?  I don't want to wind up with another 155mm monster - but I have an application that the light weight and stealth appearance would suit well.  The motor is quiet and satisfying in operation.
Can someone confirm what I'll get if I order another unit?  It really has to fit 135mm dropouts.
And, BTW - are they all silver now - or still silver/black?
Thanks!
tomasz
  • Guest
Re: Rear Mini Motor in 135mm dropouts?
« Reply #1 on: September 17, 2010, 10:55:16 AM »
Hello!
Yes - it is 135mm
Yes - it is all silver :)
Offline philf
« Reply #2 on: September 17, 2010, 08:05:48 PM »
Sweet.  Thanks for the pic!
AND it looks to take a full 7-speed freewheel!
I've ordered one :-)
Offline Phil
« Reply #3 on: October 26, 2010, 04:24:31 AM »
I'm looking to fit the 250W mini motor in a rear suspension bike I've just found, have you installed yours yet?
Has anyone managed to fit the disk rotor in the 135mm fork as well?
Phil
« Last Edit: October 27, 2010, 11:25:25 PM by Phil »
250W 36V Mini Motor
Silverback Mercury2 26" MTB
Magic controler
Ping 36V 10Ah Battery
CA
Land of OZ
