Author Topic: Installing torque arms  (Read 24266 times)
Offline mike662
« on: August 19, 2010, 04:16:11 AM »
Is there anything I should know about the do's and don'ts of installing a torque arm? I will be re-enforcing my axle area and would like to know especially whether or not I need to have the torque washers installed on both sides of the dropouts? My idea is to have nut, torque arm, dropout, washer, washer (the extra washer is for helping the off-center hub) hub motor, gears, washer, dropout, torque arm, nut. Is it bad to have the torque arms directly in contact with the dropouts? Do the torque arms need to be perfectly aligned with the frame so that they hold the axle at a perfect perpendicular angle? Will tightening and undoing and re-tightening the bolts on aluminum dropouts weaken the frame? Thanks!
Re: Installing torque arms
« Reply #1 on: August 22, 2010, 05:39:35 AM »
It will be bad if there is any gap between the two nuts on the
axle other than the drop-out slot.
As far as the order, the only important things are centering
and not springing the forks in or out.
