Author Topic: What to get in a kit  (Read 31518 times)
feltzbar
  • Guest
« on: August 14, 2010, 01:43:41 PM »
I am looking to get a front wheel 500W 36V, kit with the 36v12Ah battery.  I want to keep the kit pretty simple, but I am not sure what all parts I need. can anyone give me some advice?
Re: What to get in a kit
« Reply #1 on: August 14, 2010, 02:38:07 PM »
Hi there, ill keep it simple for you:
36v500w motorized wheel
2 button control switch - horn and cruise
thumb or twist throttle - power to go
power brake levers - cut motor when braking and enable regen
also recomend a torque arm for front wheel installation
feltzbar
  • Guest
« Reply #2 on: August 14, 2010, 09:41:14 PM »
is there a simple kit with just that stuff in it or would I have to go through the build your own kit thing.  I was looking at the build your own kit page and I didn't know what some of the options were or if they were important.
Offline karen
« Reply #3 on: August 14, 2010, 10:25:29 PM »
I used the goldenmotor.ca site to check, liked that it looked easier to find what I needed.
I also recommend better brakes than I had, depending on what your bike has. So diskbrakes and diskbrake activator.
Since I had some trouble with looking for some wireing issues I also recommend an extra Wiring harness and Connectors(Item Code: ACC-011) since I think it might have been easier to change the whole harness then fixing it. Then I also have to say that Im not good at fixing these electrical thing. And its a long wait to get it later
The wire for connecting to the controller iff you like to tamper with it.
Offline karen
« Reply #4 on: August 14, 2010, 10:26:53 PM »
I cant find torque arms on site? -make them myself?
Offline Sundsvall
  • N 62° 23', E 17° 19'
« Reply #5 on: August 14, 2010, 10:57:44 PM »
I’ll suggest that you order from goldenmotor.ca. If you have any questions Gary is present here at the forum and he seems to be very customer friendly.
Peter
« Reply #6 on: August 15, 2010, 11:54:09 AM »
Hi Karen, feltzbar
I don't normally like to solicit sales in the forum, I like to come here and read, learn and help out if possible. But it seems sometimes everyone knows more then I do!
Anyway, I have them on my site at
Torque Arm
http://www.goldenmotor.ca/shopping/pgm-more_information.php?id=110&=SID#MOREINFO
These are not GM products, but I do sell them as they are the best I can find.
Custom Kit I put together for another customer that seems to have had the same needs as you.
http://www.goldenmotor.ca/shopping/pgm-more_information.php?id=135&=SID#MOREINFO
Again my apoligies for putting these links in the forum.
« Last Edit: August 15, 2010, 12:17:52 PM by GM Canada »
Offline karen
« Reply #7 on: August 15, 2010, 02:18:12 PM »
Thanks, Gary:) Have to wait for the twelft next month since I used my paycheck to order kits from China, but I put them in my favorites. Couldnt find it in Europe, but Ill check it out:)
I had a horn on the JoyEbike I have and when I asked Tom he could send them also, even they arent on the website.
Then again I stick my nose in everything:)
