Author Topic: Do I have to wait for Magic Pie II?  (Read 22207 times)
Offline Bob91403
« on: August 09, 2010, 10:01:26 PM »
What would it take to get a Magic Pie that will handle 60V? Is 48V currently the max. (pun intended)? :D Would an external controller make a difference, or is that 48V max. also? What changes would have to be made?
Offline PEDAL IN POWER OUT
  • USA GOLDEN MOTOR DEALER
Re: Do I have to wait for Magic Pie II?
« Reply #1 on: August 09, 2010, 11:04:16 PM »
Hi Bob,
The cutoff built into the controller is 60 volts. The present generation controllers stop operating above that voltage. There are some components that have a 63 volt rating.
You do not need any modifications to run up to 60 volts. You do need to be a responsible adult who is reasonably sober.
Good luck
Offline Bob91403
« Reply #2 on: August 10, 2010, 05:51:53 AM »
Reasonably sober? While driving a car when intoxicated is a major offense here. Drunk driving on, even a motorized, bicycle in California is only a $50 fine. :P
« Last Edit: August 10, 2010, 05:54:57 AM by Bob91403 »
« Reply #3 on: August 10, 2010, 08:08:28 AM »
No!
The MP can handle voltages up to 110v however the internal controller can not.
Magic Pie, dh bike, 110v, 80kph so far<<<  Find out the Pies great performance on the smaller rim.
You can get an MP with external wires so you can upgrade the controller to 60v at anytime or seek a controller that can do 60v.
The MP motor 26" can do 60v easy. You need to know what you are doing and if not, yes you may need to wait.
« Last Edit: August 10, 2010, 08:10:53 AM by 317537 »
