Author Topic: Much More Powerful Pie Now!!!  (Read 1115961 times)
Offline o00scorpion00o
« Reply #375 on: July 02, 2011, 04:23:29 PM »
HAHA
All you crazy power hungry Bikers  ;D
Top speed on 16S LiPo on a test run yesterday was 41 mph absolute mas, average 35-38 mph! LOL
« Reply #376 on: July 02, 2011, 07:41:47 PM »
Tasty!!
Hey are you going to put bigger brake rotors on? You could get bracket adapters cheap off ebay
I hope I don't get attacked by a MAC lol
« Reply #377 on: July 02, 2011, 11:52:36 PM »
hi monkey.
Yeah I probably could. But I pedal a lot so I usually don't go near those speeds.
Really I open it up for a mlie or two. On the good road before I turn off for the bad road again.
The rotors  are fine for that.
The headset and shocks need to be replaced but I can't spend the money this year, maybe next year or I might look out for a better quality second hand bike.
« Reply #378 on: July 03, 2011, 04:29:05 AM »
That's 'cos you spent all ya money on LIPOOOOOOOOOOOOOO !!!
« Reply #379 on: July 03, 2011, 05:39:05 AM »
Haha yeah and the charger!
Though the LiPo itself isn't too expensive, the initial purchase of LiPo, charger and power supply adds up, but it's cheap then to add extra packs in the future or swap dead or faulty packs.
I miss the simplicity of bms charging and discharging. And the peace of mind in leaving LiFePO4 in the house. I store my LiPo in the shed!
LiPo is definitely not for the ordinary man. I just long for the day batteries weigh a lot less.
What I may look out for is a meanwell to bulk charge my battery without having to split up the pack to charge. It never goes out of balance if you charge to 4.15 volts and discharge to 3.5 volts. I always leave 1-2 ah just to make sure the cells stay in balance.
It would be nice if they made a battery that you could charge and discharge completely without monitoring or bms or risk of damage!
« Last Edit: July 03, 2011, 08:30:13 AM by spellchecker »
« Reply #380 on: July 03, 2011, 06:49:04 AM »
Yeah as long as you monitor them they are excellent for the $
And you only really need to balance charge them every few months or so, you will be fine charging them in series.
Although I've been maintaining my batteries, I'm still a bit unsure how they will perform once I get my bike back on the road. It's taking forever!!! Lol but small progress is better than none....
At least you are riding yours lol
« Reply #381 on: July 03, 2011, 11:31:05 AM »
Yeah Monkey,
I got my bike on the road because I'm not building a spaceship! LOL
It's going to be super when you get it running though!  ;D
« Reply #382 on: July 03, 2011, 12:21:26 PM »
Well it wasn't planned.... Put it that way lol
It will be a real definition of an e-bike 'build' though ;)
I'm slowly but surely progressing with the wiring. But see even while doing the wiring I had ideas haha I'll post them up with my build post
And I have a secret mod up my sleeve too.... :D
« Reply #383 on: July 03, 2011, 04:22:06 PM »
Lol can't wait Monkey you crazy man!
I bet 40 mph on your bike would be a lot nicer lower down!
« Reply #384 on: July 05, 2011, 06:57:52 AM »
ssshhh, don't let GM see this  :D
rewired my mac with 12G alphawire, upgraded to the compound gears...set the controller to 120%, 25 amps.......that little mutha carried me to 39 MPH on the flat.....coincidentaly I forgot to disable cruise, and my friend  tried the bike..( I havent fitted ebrakes on it yet)...he locked it from about 20MPH down to 0, not realising that cruise was locked on......motor shuddered to a standstill hopping everywhere ( with controller at 30 amps)...4 seconds before controller shutdown.....no damage whatsoever to the compound gears......they got my vote....
Will re-wire this motor shortly with much thicker phase windings.....
« Reply #385 on: July 05, 2011, 10:45:45 AM »
hey ginge.
you should try 40 amp battery and 90 phase  ;D
Offline johan_heyrman
« Reply #386 on: July 13, 2011, 12:45:43 PM »
I'm tempted to do some McShunting... But I have a sneaky 'soft' mod I wan't to try first..... Details updated here!!
I'm curious about that soft mod, could you share more information please.
Offline JS
« Reply #387 on: July 29, 2011, 09:26:35 AM »
Almost didn't find this, since it isn't in the Magic Pie-section... anyway, I saw some helpful pictures in this thread and I think I have a pretty good idea what to do, but just in case I'll confirm it with the Masters  ;)
Here's a picture of my MP2, which I'm not entirely satisfied about. It's definitely the tamed 700-800W version. Just a few hundred watts more might do it.
Battery is 48V LiFePo4 2C, so there's plenty of power available for the Pie.
Questions:
(A) is the shunt loop that's essentially a current constrictor, or resistor whatever?
(B) is the shortcut I should solder on?  Or just make (A) stronger with a parallel wire?
Any sense in strengthening (C)?
Offline JS
« Reply #388 on: July 30, 2011, 09:25:57 AM »
Ok, the deed is done. Now it has POWER, maybe even too much, we'll see. I'll try to use it sparingly :)
« Reply #389 on: July 30, 2011, 12:42:26 PM »
You should probably buy an egg timer too, so you can measure how long it lasts :D hehe
Good work on the mod, is your bike making wheelies now?
