Author Topic: My Magic Pie Bike  (Read 92471 times)
Offline gamewinner
My Magic Pie Bike
« on: June 02, 2010, 08:51:36 AM »
I bought a Magic Pie motor on 21 May and I have no news about the delivery !
I contacted the sales by mail but I have no answer.
Can someone of sales can contact me by MP so I can give him the Paypal Operation ID in order to have some infos of my command ?
Kreshnik
« Last Edit: June 24, 2010, 06:46:22 AM by gamewinner »
Re: Don't have news about my Magic Pie command
« Reply #1 on: June 02, 2010, 11:02:40 AM »
Kreshnik
Who did you buy it from? Do you have a receipt or invoice number?
Offline gamewinner
« Reply #2 on: June 04, 2010, 07:12:39 AM »
I bought it from goldenmotor website.
Tom contacted me : the kit is not yet shipped.
I am waiting  :'(
« Reply #3 on: June 04, 2010, 07:46:58 AM »
I am waiting  :'(
Oh that was that big box at the door was.  They must of sent it to me by mistake.
Just kidding.   ;D
Hang in there buddy the Pie will be served.  I know these hunger pains, well.  Good chance you get the Pie 1.01 is worth the wait.
Offline gamewinner
« Reply #4 on: June 11, 2010, 10:45:24 AM »
It's me again. Tom don't answer to my e-mails anymore !
How much does it takes normally to recieve a command from goldenmotor because I'm waiting for 3 weeks and I think the kit is not alseady shipped ?
Offline gamewinner
« Reply #5 on: June 17, 2010, 06:51:33 AM »
Nobody can answer me !
« Reply #6 on: June 19, 2010, 02:07:18 PM »
Unfortunatly GM China is the busiest place on the planet. Some shipping delays are as long as a month right now. Hang in there it will come. It is difficult for Tom to reply to all the emails he receives as he is the shipper and tech support guy and is currently overwhelmed by the busy season. I wish there was more staff in China to assist him, but that is out of my hands.
« Reply #7 on: June 20, 2010, 12:01:49 PM »
We still hear you.  Your calls will not be forgotten and left to fade into the static background noise of the abysses.
It is a bad feeling waiting so long.  The only thing that will cheer you up is a good Pie hey.
If nothing happens soon you bump this along till something happens.
It will happen, and I hope for you soon.
« Last Edit: June 20, 2010, 12:03:43 PM by 317537 »
Offline mike662
« Reply #8 on: June 20, 2010, 03:55:22 PM »
I ordered my kit on May 29th and am still waiting too :( Hopefully it'll come this week.
Offline gamewinner
« Reply #9 on: June 22, 2010, 10:56:11 AM »
Hello everybody.
Just a little message to say that I received today my Magic Pie Kit ;)
Re: Pie finally arrived
« Reply #10 on: June 22, 2010, 12:02:11 PM »
That's good news Kreshnik.
Now you just have to fit it and start enjoying it, and I'm sure you'll agree it was well worth waiting for.
It would be nice to see some pictures when it's complete.
« Last Edit: June 30, 2017, 07:31:53 PM by Bikemad »
Offline gamewinner
« Reply #11 on: June 23, 2010, 09:13:04 AM »
I'm working on it. I promise to put some pictures when it's done ;)
« Reply #12 on: June 23, 2010, 12:43:05 PM »
Great news
Just some hints.
Always assume this gear all works and install it as such.  Skip tests.
This is not a dress rehearsal this is the real thing.
Take your time make sure.
All the connections correct are secured and can not move.
Derailer adjusted and so it cant rub against the hub wall gear face.
Battery attached rpoperly to the bike.
Charge battery.
Rear and front Axel bolts done up tight, all your might.  Not flare the dropouts tight.
Goose neck and handle bars and seat posts are tight and other bolts n nuts. Dont put too much tension on the stem bolt.
Throttle grub screw tightened properly.
Brakes calipers, switches, (PAS) installed securely and adjusted
Torque arm in place and secured.
Brakes adjusted to centre and rim true.
Pump the tires to max can avoid rim damage on bumps. Maybe a little max under, not over.
Wear a helmet and
Take your time around people. I like to show off how slow it can go.  These bikes can travel as slow as a snail. with delicate throttle control.
Good luck.
Recheck all the above.
« Last Edit: June 23, 2010, 12:58:23 PM by 317537 »
Offline gamewinner
« Reply #13 on: June 24, 2010, 06:45:56 AM »
Thank you for your help ;)
- I mounted the MP with the connectors
- I'm waiting for the Torque Arm
- When I tested the battery (no GM Battery) I can see 0V ! I've to test with another one.
- The battery will be in my backpack
Offline gamewinner
Re: My Magic Pie Bike
« Reply #14 on: June 24, 2010, 10:22:40 AM »
I have a question : Can I use my ebike (Magic Pie) without the battery ? Is it dangerous for the controler ?
« Last Edit: June 24, 2010, 11:37:44 AM by gamewinner »
