Author Topic: Battery Cells Should I get these  (Read 28079 times)
Offline MasterCATZ
« on: May 09, 2010, 11:31:15 PM »
http://cgi.ebay.com.au/LiFePO4-10AH-cell-3-3V-8C-electric-bike-bicycle-battery-/320528935935?cmd=ViewItem&pt=AU_Electronics_Batteries_Chargers&hash=item4aa1036bff
expensive almost $2k to build an 8C 72V 20 ah kit ... but Very light under 10kg
around 200mm * 240mm in size for the bank
anyone know of something cheaper / better ?
Offline muzza.au
Re: Battery Cells Should I get these
« Reply #1 on: May 10, 2010, 08:44:56 AM »
Yes I do!
Are you in Aussie land also?
If so check out EMTB. They use Headway packs and cells and they are cheaper than the one on ebay, but look identical.
See http://www.e-mtb.com.au/lithium-batteries-c-75.html?zenid=48842e91850b9399769d6e58ff93ca83
They have packs already made up that would be cheaper than building your own, although their chargers are more expensive.
I have 2 of the following chargers (a 24v and a 36v), cheap, but work very well: http://cgi.ebay.com.au/Newest-36v-220v-5A-Charger-LiFePo4-battery-Power-FS-/170484254939?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item27b1a748db
If you really need 72v 20ah, you could buy 4 of their 36v 10ah packs @ $390.00 each plus you would need 2 36v chargers (another $100.00) which would be about $1660.00 (plus postage if necessary).
Do you really need all that much capacity (v and a)?
Muzza.au
« Last Edit: May 10, 2010, 08:52:27 AM by muzza.au »
Offline MasterCATZ
« Reply #2 on: May 10, 2010, 12:33:02 PM »
cheers and yep another OZ
those batterys are only 5c but half the price ... mmm how much regen recharge would 2x MP2's do ?
wanna do dual MP2
need something that can handle regen load of 2x MP2
and want the SPEED :P
tho I might just have an toggle switch to go between 36v 40AH and 72v 20ah
still not to sure about what to do about the bike light system
maybe only 72V at daytime ....
« Last Edit: May 10, 2010, 12:47:39 PM by MasterCATZ »
Offline muzza.au
« Reply #3 on: May 10, 2010, 08:11:13 PM »
Do what I did, use dc-dc converters. My bike is 60v. A 36v plus a 24v. I can run it on 36v only or switch on the 24v for 60v (which I do 99% of the time). With the dc-dc converter it makes no difference to the lights.
Muzza.au
