Author Topic: Regenerative charging wiring  (Read 38319 times)
Offline Gapy
« on: April 10, 2010, 05:53:31 PM »
Hey guys... Can someone tell me if I am on the right way, or am I gonna fry everything?
Any of you tried to connect it without the diodes?
Rear GoldenMotor Magic Pie
48V 20Ah LiFePo4
top speed: 48.6km/h
range: 55km at full speed
TRK
  • Guest
Re: Regenerative charging wiring
« Reply #1 on: April 11, 2010, 01:04:37 AM »
Assuming this is done because the battery has separate charging wires, the direction of the diodes seems okay to me.
And no, I haven't tried that without the diodes as I have a regular GM pack.
« Last Edit: April 11, 2010, 01:06:08 AM by ceZar »
Offline Gapy
« Reply #2 on: April 11, 2010, 10:13:46 AM »
Ok... Can anyone give me a block scheme of a GM battery? I really want someone to confirm my wiring, before I connect the LiFePo4 battery...
Also-what is the range of GM battery 48V12Ah-with Magic Pie?
48V 20Ah LiFePo4
top speed: 48.6km/h
Offline gf3
« Reply #3 on: April 11, 2010, 04:34:53 PM »
I bought a ping battery and all I needed to do was use one diode in the black main power lead and then conect the black recharge lead to the end of the diode. I will see if I can find the circuit diagram.
« Last Edit: April 11, 2010, 04:45:45 PM by gf3 »
Offline Pwd
« Reply #4 on: April 11, 2010, 04:41:00 PM »
I'm using the 48V 12aH on my Magic Pie and at 80-100% throttle with peddling it lasted about 37 km. Thats just a real world stat for the area I was riding in. I bet if I slowed down and used 50% motor and 50% muscle I could go 40+ Km.
Offline GM Brazil
« Reply #5 on: April 11, 2010, 04:51:24 PM »
I got between 22km and 25km without pedalling
Offline Hardcore
« Reply #6 on: April 11, 2010, 08:03:27 PM »
30 without winds hills and traffic lights
but 25 definitely
Offline martin
« Reply #7 on: April 16, 2010, 01:13:54 PM »
35km with consideration, 22km full power and no pedalling on 48v 12ah (approx)
