Author Topic: open minimotor 250w  (Read 29584 times)
Offline perdigon
open minimotor 250w
« on: April 02, 2010, 01:37:45 PM »
anyone knows how to open a mini-engine 250w
Re: open minimotor 250w
« Reply #1 on: April 02, 2010, 02:47:38 PM »
The photos in this post might help.
Offline perdigon
« Reply #2 on: April 02, 2010, 03:41:01 PM »
the engine is back
Offline perdigon
« Reply #3 on: April 02, 2010, 11:29:29 PM »
I see no way to open the engine
Re: Opening the 250W minimotor
« Reply #4 on: April 03, 2010, 12:44:48 AM »
Your minimotor is different to the others that I have seen, but I would say the left hand cover must be unscrewed
using a tool like the one shown below:
                                   This one
It's the only way that I can see to open it.
Offline perdigon
« Reply #5 on: April 03, 2010, 01:17:02 AM »
ok thx alan
« Reply #6 on: April 05, 2010, 03:54:08 AM »
You could use a mallot and a centre punch to unscrew the cover but that may be a bad thing and cause damage.  You could cut the tool drill three holes and use high tensile screws to make the three pins. Or find some junk and get a steel disk with no centre, drill three holes and secure three pin screws that extend out from the other side and use a lever or large screw driver in between the screws and turn..
