Author Topic: PI200 Controller program  (Read 30484 times)
Offline Svendus
  • to live means to learn
    • Svendus Data
« on: April 02, 2010, 06:57:20 AM »
PI200 Controller program version 1.0 is running nicely on Windows seven thank you
but I  have maybe missed the manual for this program where do I find it ?
« Last Edit: April 02, 2010, 06:59:05 AM by svendus »
Offline PEDAL IN POWER OUT
  • USA GOLDEN MOTOR DEALER
Re: PI200 Controller program
« Reply #1 on: April 02, 2010, 02:23:22 PM »
Greetings svendus
Do you have it plugged into the controller?
So far it seems to run on seven, 2000, xp.
I would try my vista machine, but it is doing such a good job as a paper weight.
Documentation? I would settle for the USB device driver.
« Reply #2 on: April 02, 2010, 03:22:03 PM »
Svendus,
I don't suppose there is a manual for this program, as most of the settings would appear to be pretty self explanatory, but the tool tips for the reverse mode options are useful.
If you can establish a connection I would suggest you try and get the current configuration from the controller and then save it as "Original setting" so you have somewhere to start from if you somehow mess it up. ;)
I tried the program on both Windows ME and XP and it seems to run fine, but I don't have either the interface cable or a suitably wired speed controller, but I'm pretty sure that my mx-315 Magic pie controller would be compatible if it was rewired to suit.
« Reply #3 on: April 02, 2010, 06:49:09 PM »
Great photography and map of the functions Bikemad!
Here is pie controller internals with a 2.0 sticker.
Pie II is going to need more wires in the pigtail in addition to the higher voltage caps.
There needs to be one more data line for 2 way usb.
Has anyone counted the pins for the Pie II programming cable? If it is more than 8, you are seeing the future.
Are we going to a 9 or more wire pigtail?
Offline Svendus
    • Svendus Data
« Reply #4 on: April 02, 2010, 07:23:06 PM »
Thanks we will save the factory default
the alarm do however not function on the new controller
