Author Topic: mechanic : how to open the rear wheel ?  (Read 37176 times)
Offline caradec
« on: October 22, 2007, 09:44:48 AM »
Now another problem, rather mechanical than electronic : in order to check my sensors, I need to open the rear motor. No problem for one side, but I don't see how to remove the freewheel.
Do someone know how to proceed ? Thanks.
Offline mustangman
Re: mechanic : how to open the rear wheel ?
« Reply #1 on: October 22, 2007, 04:03:29 PM »
Yoy need the tool to remove the freewheel, so the easiest way is take it to a bike shop and let them pop it off in a minute.
Offline caradec
« Reply #2 on: October 23, 2007, 07:53:20 AM »
Maybe I am wrong, but it seems that the freewheel -I mean the "gables" (right translation ?)- is mounted on the axle, so I can't remove the cover. Unfortunately the sensors are on this side of the wheel.
http://goldenmotor.com/e-Bike-DIY/Rear%20Wheel%20Bike%20Conversion%20Kit.jpg
Offline caradec
« Reply #3 on: October 23, 2007, 07:59:21 PM »
I think it is a good advice MEB, thank you.
Offline Dave
    • davintosh
« Reply #4 on: October 23, 2007, 08:36:44 PM »
Actually, the freewheel threads onto the hub cover. So if you remove the screws around the perimeter of the hub, the face of the hub and the freewheel will come off together. Just make sure you remove the axle nut first.
Offline caradec
« Reply #5 on: October 23, 2007, 08:54:16 PM »
Well done, Dave, you're right ! I didn't dare to force it because it was hard, but after reading you, I insisted, and it finally came with the cover.
Now I have to find new sensors and try to change them. I will tell you.
Thanks a lot.  :)
