Author Topic: What's the safest level for an LVC of a 36v LiFePO4  (Read 31748 times)
Offline Sangesf
« on: March 09, 2010, 09:32:59 PM »
I'm using the 24v minimotor with a 36v 14ah LiFePO4 battery and would liketo setup my BMS with the best LVC for that battery...
Voltage per cell group should be what?
Re: What's the safest level for an LVC of a 36v LiFePO4
« Reply #1 on: March 10, 2010, 12:00:29 AM »
Frank,
Without knowing exactly which battery you have, it's difficult to say.
If you're using a GM LiFePO4 I would guess somewhere around 2.8V per cell would be a reasonably safe cut off voltage for this battery, based on their charging graph:
The maximum charging voltage should provide some clue as to the actual voltage of the individual cells.
