Author Topic: So who here is good at math?  (Read 32831 times)
3Vz9Ycvx
  • Guest
« on: January 30, 2010, 07:27:40 AM »
I'm starting to really geek out on the numbers and terms - Watts, Amps, Volts, RPMs.
I'm psyched to get to work on my first eBike.
I also want to learn the math so I can better customize my ride.
Can anyone here direct me to a beginner's guide or a post or any place where I can get started learning what all the technical terms mean and how the math works (the basic equations and stuff to get me up and running)?
Much thanks in advance,
- Brett
3Vz9Ycvx
  • Guest
Re: So who here is good at math?
« Reply #1 on: January 30, 2010, 08:18:17 AM »
OK, so first I need to brush up on my metric measurements.
I just found out that the United States is one of only three countries (the others being Burma (Myanmar) and Liberia) that have failed to adopt the SI.
Very embarrassing. Please don't hold it against me.
About batteries:
They are measured in volts and amps.
An increase in voltage results in increased weight and increased power (push through the circuit, balls, guts, omph ... you get the idea).
The balance between weight and power is efficiency.
Am I getting this right so far?
Questions:
What affects efficiency in a battery? Are LiPoFe batteries more efficient than SLAs?
Can I control it in some way or is it part of the manufacturing process?
More to come ... please feel free to jump in ...
Best,
- Brett
3Vz9Ycvx
  • Guest
« Reply #2 on: January 30, 2010, 09:22:26 AM »
Here's a great primer on electricity using the "Hydraulic Analogy."
If you can understand water going through pipes, reservoirs and water wheels, you can understand just about any electrical component from a resistor to a diode to a capacitor and on and on ... pretty cool.
I'm still working my way through it, but I already understand volts and current (amperes) better.
http://en.wikipedia.org/wiki/Hydraulic_analogy
3Vz9Ycvx
  • Guest
« Reply #3 on: February 01, 2010, 09:46:24 PM »
Here's a handy little primer on electrical circuitry related to EVs:
http://www.efmotion.com/2010/01/electricity-for-non-electricians-ev.html
