Author Topic: Rebuilding my 45km/H scooter with MW16C and HPC100B  (Read 119952 times)
Re: Rebuilding my 45km/H scooter with MW16C and HPC100B
« Reply #15 on: May 18, 2010, 09:48:15 AM »
Eriknoort,
This is the CONSUMED power :D do not confuse with the delivered power that should be less 'causu of common losses like friction and heat. But still a lot of power :D
Take 20% off for efficiency which is measured from Newton meters per amp volt and watt, and he still has a 6.5kw output.
Offline Eriknoort
« Reply #16 on: September 09, 2010, 08:53:08 PM »
Here is an update.
After destroying my front rim, I replaced the front suspention and front wheel with a bigger one.
The original front wheel was 10" now its a 12" wheel with diskbrake.
The rear tyre was worn out after 4500 km, I replaced the original 10x3.50 with a much bigger 120/90-R10.
This is resulting in a better handling and comfort of the scooter.
« Last Edit: July 09, 2013, 12:27:05 AM by Bikemad »
« Reply #17 on: September 10, 2010, 11:13:26 PM »
Looks comfy
Does it do good burnouts?
:D
« Reply #18 on: November 25, 2010, 10:10:11 PM »
Yes but even at 50% efficiency thats still 4000+ watts.  As opposed to the true output of any other hub motor.
65kph and 97km range.  Awesome.
