Author Topic: HOW TO CONVERT THE STANDARD 36V CONTROLLER IN REGENERATIVE?  (Read 37847 times)
Offline Electric_Bike_2007
« on: September 14, 2007, 07:08:08 PM »
Hi all. :)
Last weekend,I noticed that if you unplug the batteries ,the red led indicator turns on(battery meter), when you use the bike(with batteries unplugged)
So... the question is: Is it possible to convert the original controller(36v) to work as a regenerative controller as well?
Maybe using some diodes and switches... (and or mosfets)?
Can the hub motor be adapted to work in generator mode?
Is it similar to a car alternator?
I will try to do some tests here...
My bike is working well, I just need to fix that cut off voltage issue..
Regards and have a nice weekend!
Offline myelectricbike
Re: HOW TO CONVERT THE STANDARD 36V CONTROLLER IN REGENERATIVE?
« Reply #1 on: September 14, 2007, 09:02:39 PM »
Unfortunately it is less expensive in time and money to purchase a regenerative controller than to make one yourself since the lower price of a manufactured one comes from lower cost per unit due to volume sales once design costs and tool up are paid. You can build a circuit to tap the output from a hub motor by starting here.
Offline mustangman
« Reply #2 on: September 14, 2007, 11:22:38 PM »
I guess I will have to wait for the 48volt regen controller. :)
