Author Topic: Cycle Analyst (throttle over-ride function) with MAGIC PIE  (Read 45881 times)
Offline asker
« on: October 25, 2009, 02:39:44 PM »
Hi
how to conect the throttle override signal of Cycle Analyst SA (Stand Alone version, with external shunt resistor; the only problem is where and how to connect the Th signal wire)  to the Magic Pie?
thanks for your answers
« Last Edit: October 25, 2009, 06:26:55 PM by asker »
Offline rolf_w
Re: Cycle Analyst (throttle over-ride function) with MAGIC PIE
« Reply #1 on: October 25, 2009, 04:56:35 PM »
I guess the MP controller is the same as the BAC controller used for the other GM motors. I tried to figure out the CA connections to some internal pad or pin (see http://goldenmotor.com/SMF/index.php?topic=1151.msg6451#msg6451) . I would use the solder pad for the throttle signal to connect the MP controller. r
