Author Topic: Spacer tube  (Read 21951 times)
Offline scott
Spacer tube
« on: October 12, 2009, 07:36:27 PM »
On the 48v rear wheel is the spacer tube suppose to protrude past the cassette? Mine does not.The first rectangular slotted washer is riding on the cassette not the spacer tube.
Thanks Scott
Re: Spacer tube
« Reply #1 on: October 12, 2009, 11:59:36 PM »
Scott,
The spacer tube should protrude past the freewheel, it sounds like you you will need to add a couple of suitable washers between the spacer and the slotted washer to provide clearance for the freewheel.
