Author Topic: Shim thickness and placement  (Read 25763 times)
Offline scott
« on: October 11, 2009, 01:19:39 AM »
I tried a thin shim . Did not help.
Re: Shim thickness and placement
« Reply #1 on: October 11, 2009, 11:32:40 AM »
Scott,
A thicker shim (or additional thin shims) may be necessary.
N.B. The shim should fit over the threaded boss section of the hub before the freewheel is threaded on.
Not inside the threaded portion of the freewheel as your photo appears to indicate:
« Last Edit: June 30, 2017, 05:31:59 PM by Bikemad »
Offline Phil
« Reply #2 on: October 16, 2009, 07:54:20 AM »
I had this problem as well, but a shim over the boss threaded section did not work as the freewheel, shim & hub were still locked together. I did solve the problem by putting a shim inside the freewheel in the place you have on your photo. That gave space between the freewheel & hub. Seems to be working OK for a month now.
Phil
250W 36V Mini Motor
Silverback Mercury2 26" MTB
Magic controler
Ping 36V 10Ah Battery
CA
Land of OZ
