Author Topic: Got the spacers in and the wheel is off the frame.  (Read 27864 times)
Offline scott
« on: October 10, 2009, 09:32:45 PM »
Wheel was spinning nicely until the free wheel (6 speed gear tightened up).Binding soon ensued. I think it need the shim(washer?). Where does it go?
Tkanks
Scott
P.S I set two U clamps on both sides of the rear frame and ran a cable tightener between them .Turning the cable tightener backwards .Work like a charm for spreading the rear axel gap on the frame.
Cost me 3.75 CDN. Save me “finger knuckle abuse”.
I will send a picture ,,,,,when I find out how.
Re: Got the spacers in and the wheel is off the frame.
« Reply #1 on: October 10, 2009, 09:46:04 PM »
Scott,
The shim needs to be fitted between the freewheel and the hub.
If you want to include an image with your post, then use the 'additional options' and browse
to the image on your computer.
« Last Edit: June 30, 2017, 05:33:04 PM by Bikemad »
Offline scott
« Reply #2 on: October 10, 2009, 09:56:11 PM »
Thanks.
