Author Topic: 67V on 48V-Goldenmotor  (Read 35195 times)
Offline Optima25
« on: October 08, 2009, 04:50:03 AM »
hello friends
I have a simple question: can the 48V Controller also handle 67V? I tried this setup yesterday for only 5 minutes. The speed is amazing guys!!!! I would love to drive always with this speed.
And also: why does the controller makes a stop and go function after 30min. of driving? Is it because of the heat? Or because of Volt?
Please help ;-)
thanx
Optima from switzerland
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
    • GoldenMotor Youtube
Re: 67V on 48V-Goldenmotor
« Reply #1 on: October 08, 2009, 05:21:09 AM »
Heat and current overflow protection.
It shouldn't be able to run at 67Volts, I guess your battery is not truly 67 Volts.
Max volts it will tolerate is 60
Offline Optima25
« Reply #2 on: October 08, 2009, 05:24:06 AM »
no sorry - its exactly 67.2V ....16 Lipo-Cells!!! And it works great!!!
But I am not sure will it have a short life ...anybody expiriences???
Offline Optima25
« Reply #3 on: October 08, 2009, 05:29:32 AM »
current overflow protection?? How can I drive without any problems for half an hour and it is starting then?
It must be the hear ..isn't it?
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
« Reply #4 on: October 08, 2009, 05:32:17 AM »
Oh i'm sorry, the 60V cut out is for the Magic Pie controllers.
Your magic controller is not recommended for 60 volts and above but it will work. Play with caution then.
Anyway can you post more details?
Max speed or something.
Offline Optima25
« Reply #5 on: October 08, 2009, 05:36:41 AM »
I tried 16 x 4.2V Lipo 8ah = 67.2V
The speed was around 60km/h without my help!
I have Goldenmotor 48V 1000W with Goldenmotor Controller
How long do you think will it live with so much Volts???
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
« Reply #6 on: October 08, 2009, 06:57:52 AM »
that is a deadly speed
« Reply #7 on: October 08, 2009, 09:54:00 AM »
If you keep using it at this voltage, I expect you will find out. ;)
Offline Optima25
« Reply #8 on: October 09, 2009, 03:10:55 AM »
nobody expieriences with 63V??????
