Author Topic: battery box using water bottle holes?  (Read 46082 times)
Offline Akis76
« on: September 09, 2009, 09:56:58 PM »
is there any battery box that can be installed into the water bottle holes of our bikes?
I mean something like this
is there any chance that gm will do this in future?
« Last Edit: September 09, 2009, 10:43:21 PM by Bikemad »
Re: battery box using water bottle holes?
« Reply #1 on: September 09, 2009, 10:36:46 PM »
PowaByke's 36V 6Ah lithium-ion power pack disguised as a water bottle:
If there was a great demand for them, I'm sure GM would consider marketing them.
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
    • GoldenMotor Youtube
« Reply #2 on: September 10, 2009, 12:10:41 AM »
Yes, we will make it available this year.
Offline Perbear
« Reply #3 on: September 10, 2009, 08:23:15 PM »
Excellent!
What capacity will the battery have?
Offline jarocue1
« Reply #4 on: September 11, 2009, 10:52:30 AM »
Good.... What capacity the battery have and what is the dimentions bottle have... aproximity?..... is very interesting.
« Reply #5 on: September 11, 2009, 11:02:12 AM »
I expect it will be a box style rather than a bottle style in order to accommodate a reasonable battery capacity.
Offline Akis76
« Reply #6 on: September 11, 2009, 12:40:49 PM »
we re waiting for this!!! 8)
Offline Perbear
« Reply #7 on: September 12, 2009, 09:56:18 AM »
I built an experimental battery pack using two 19V 4900mAh LiPo packs in series with a simple balancer board, all wrapped up in a shrink-fit sleeve. The weight is 1,22 kg and gives about half the range compared to my 10Ah 36V GM pack that weights around 5,2 kg. The LiPo (lithium-polymer) pack fits in a slightly expanded bottle holder but it is not a safe battery pack, missing temperature sensors, waterproofing and mechanical protection. All this is required to have a safe pack.
Many houses and garages have, and will, catch fire due to ebike battery packs not being built safe enough. Check out http://www.extraenergy.org where some examples can be found. Also call your local fire department and ask if they know about any fires started by lithium batteries...
Offline Akis76
« Reply #8 on: September 17, 2009, 12:38:54 PM »
i didn't mean a pack fitting in a bottle holder but a box insalled using the bottle holes like the bionx battery...
Offline robertozm
« Reply #9 on: September 19, 2009, 09:56:24 AM »
Hi.  I made a box with aluminium sheets, and it is bolted to the water bottles holes ( I have 2 pairs) and also I have another attachment to the frame of the bike at the top right angle corner.  http://goldenmotor.com/SMF/index.php?topic=437.0
You can also have a look at this
http://endless-sphere.com/forums/viewtopic.php?f=3&t=12847
Hope it helps  ;)
