Author Topic: calibrating motor with new cruise control controller  (Read 26345 times)
Offline b.raaymakers
« on: July 08, 2009, 09:34:07 PM »
HI,
i'd like to know if I can use this procedure to calibrate again the goldenmotor motor.
8. Motor phase Calibrating (Do not use it unless your motor is not from GoldenMotor):
The controller can work brushless motors with different phase angles other than defaulted 120 degree.
Below are procedures to let controller match the motor phases:
• Cut-off power to controller and motor
• Grip and hold power brake lever, turn throttle to maximum speed position, depress the cruise control
• button, turn on the power switch (using battery key)
• Connect battery power to the system, release throttle, release brake lever, release cruise control
• button.
• Listen 2 beep sound, turn the motor wheel forward and reverse once
• If hear 1 beep sound, motor phase calibrating successfully completed.
• Otherwise, swapping any two of three motor phase wires, and repeat above steps.
because I have some noise in the wheel at 34 Kmh to 37 Kmh its really boring it sounds like a resonnace.
do you know what to do to fix that?
