Author Topic: Brake by reversing  (Read 170727 times)
Offline Pontus
    • Grinde 19
Re: Brake by reversing
« Reply #15 on: May 18, 2025, 08:13:13 AM »
I think I have the TRC010, although not 100% sure. The connection was straight forward though, just plugging in the connectors.
I also experienced shuddering at higher revs. That was due to an firmware update changing the scale of controller setting but without the actual settings being changed accordingly. That was solved by an email to GM though.
Here's my blog post about installing the throttle.
On page Google translation available.
https://grinde-19.se/blog/nytt-gasreglage
Follow along my electric conversion of a 4 ton Danish sail boat. Grinde 19
Offline Johnculley
« Reply #16 on: May 18, 2025, 08:17:29 AM »
The 010 is a round handle, the 012 has a wider flat section at the top. I had lots of trouble connecting because I followed the instructional video for the 010 😩.
I’ll have to email GM again about the shuddering. It happens around 2100 rpm and 2600r (rotor speed on the app).
Offline Pontus
    • Grinde 19
« Reply #17 on: May 18, 2025, 06:23:22 PM »
On the pictures I find online it seems the trc-012 has some sort of power display. If that's the case I imagine there are more connections.
Offline Johnculley
« Reply #18 on: May 18, 2025, 06:25:58 PM »
It’s a battery level meter and quite accurate. The. Buttons are on/off and speed mode, which doesn’t seem to make any difference. You can also use the buttons to reprogram the throttle so it works the opposite way round.
