Author Topic: Dewalt 36 volt batteries  (Read 207893 times)
Offline OneEye
Re: Dewalt 36 volt batteries
« Reply #60 on: September 15, 2007, 09:29:28 PM »
If cared for correctly, the Li-Ion packs you purchased should serve well.  2,000 cycles would be too much to expecte out of Li-Ion however.  Remember not to store them for long periods of time at full charge or near full discharge, the chemistry tends to eat itself under these conditions.  Li-Ion has the greatest longevity if keept between 30% - 70% state of charge.
LiFePO4 is the new kid on the block, with a lot of hype to go with it.  The LiFePO4 is overpriced like the iPhone when it was released.  Hopefully over the next year or so the price will slide by about 25%.
Or maybe the DeWalt service center in Fresno will start delivering damaged packs to mustangman by the truckload instead of paying to ship and recycle them.  Then we could get packs from him for say $15 each.  If 2 out of 3 cells are good that comes to less than $25 per pack ;D
One can always hope.
Offline OneEye
« Reply #61 on: September 15, 2007, 09:39:12 PM »
esource,
You may want to tinker with the low voltage cutoff on your controller anyway.  According to the specs you posted your pack cutoff is 26V.  Unmodified, the goldenmotor controller will cut out at 31.5V.  pdonahue posted the equation and resistor locations for adjusting your cutoff voltage in the "cutoff voltage" thread.  It shouldn't be too dificult to set up.
Offline mustangman
« Reply #62 on: September 16, 2007, 07:06:37 PM »
 Sorry no luck yet, probably because there is not too many out in the field yet! Patience grasshopper, we will soon be rewarded for our efforts!! ;D
