Author Topic: Can MPII handle 2x48/10 batteries?  (Read 49208 times)
Re: Can MPII handle 2x48/10 batteries?
« Reply #15 on: May 10, 2013, 06:55:26 PM »
Hi Zero,
The load is largely what determines power drawn from a given voltage.  Households are commonly capable of supplying 200+ amps, but the 100 watt light will only draw about an amp. If you want to draw more amps, you screw in a 200, or 500 watt bulb.    In the case of your MPII, at 48 volts, it is your MP2 that is limiting the power drawn, be it from 1 48V battery or 100 48V batteries.  (Yes, Alan, there will be sag effect variation) .
Perhaps you should be looking at the programmed limits in your MP2.  I have absolutely no knowledge about the MP2, but Alan recently said he was drawing close to 100 amps with a modified Pie.  :)
We really need a "Big Grin" button for talking about 100Amp Pies..... ;D  Maybe this is it...
I hope this helps.
Offline Zero
« Reply #16 on: May 10, 2013, 08:49:15 PM »
Can anybody say what is the maximum amperage, that passes the unmodified mp2 internal controller shunt @ 50V, that is actually what i've been trying to find out with my few last posts.
Offline Phil O Dendron
« Reply #17 on: May 11, 2013, 11:33:03 AM »
Zero,
sorry, I assumed you already got the programming interface cable  :)
Can only talk about my Magic Pie 2 with internal controller, pcb revision mx328.
I could not get more than 15 ampere without modification with a Zhenlong 36V 10ah li-ion battery.
Changed the battery to a diy 12s5p pack made of samsung icr 18650 cells, no bms.
Still not more than 16 ampere.  >:(
I used the cruise controller software revision 200 at that time.
Then I improved the soldering on the pcb, "beefed up" the high current tracks with copper wire,
replaced the two capacitors rated 470uf / 63v with 6x 330uf / 80v /125°c.
Result: 25 ampere peak  :)
The shunt was not touced at this time.
Next stage: bridged about one third of the shunt with copper wire and changed software to rev. 280 (or 282, not sure).
Result: when settig peak current to 70 amps the wattmeter showed 50 amps peak.
Turned it down via software to 55 amps peak, resulting in 40 amps shown on wattmeter.
So I assume you could get more than 15 or 16 amps just with using the newest software and the programming cable.
Hope that helps.
Cheers, phil.
Offline Zero
« Reply #18 on: May 11, 2013, 07:25:18 PM »
That was informative, thanks! I'll post my progress here, so stay tuned :)
