Author Topic: Earth Day , too bad my Pie doesn't work , Bikemad found the problem  (Read 67704 times)
Offline Rodmiami
Re: Earth Day , too bad my Pie doesn't work , Bikemad found the problem
« Reply #15 on: May 02, 2012, 01:01:11 PM »
 Alan ,Thanks again . Gary and I are starting to communicate . I tried it yesterday after the reverse charge with my old charger the light was still green when plugged in to the charge port . I will try again later today . Rod
Offline Rodmiami
« Reply #16 on: May 04, 2012, 03:34:11 PM »
Alan , just as I thought , they don't make that battery anymore . Even though it is still under warranty . Gary is going to check and see if he has a matching BMS , I sent him a photo this morning . The serial numbers are easy to read on the photo . We'll see what happens . The battery only charges through the Anderson connector . My concern is that the cells will not level out . Rod
Offline Rodmiami
« Reply #17 on: May 05, 2012, 03:33:45 PM »
Bikemad if you are out there. The charger actually went from red to green in the reverse mode ( using the Anderson connector as a charge port ) indicating a full charge . I turn it off when I notice that the charge is full , simply turn off the key . Then in couple of hours I turn on the key switch , if it goes red I wait till it turns green again . I am trying to balance the battery , letting it rest . With a full charge the bike performs as before . The charge port still does not work . Rod
Offline Rodmiami
« Reply #18 on: May 11, 2012, 01:14:36 PM »
This  is an update on the BMS problem that I had . Gary / GM no longer have Lithium ion batteries nor do they  have replacement BMS's . Gary offered me a discount on a LiPo4 battery so I took it . Thanks Gary . I feel for Gary, its like he is the go to guy if you have a problem with a GM product and hopefully he is being covered in his expenditures from GM . Rod
« Reply #19 on: May 26, 2012, 02:02:18 PM »
Actually China's opinion is "we no longer can supply any replacements for those batteries. Just offer him a discount on a new one"
The discount comes from my pocket not theirs. I just didn't want to leave you at a loss as I do care about my customers.
Offline Rodmiami
« Reply #20 on: May 28, 2012, 03:28:50 PM »
Thanks again Gary , The new battery works well . Rod
« Reply #21 on: May 28, 2012, 08:41:43 PM »
I wonder if Pinner has read this.....
« Reply #22 on: May 30, 2012, 03:27:38 AM »
Unlikely but China did and their reply was back in reply number three of this thread
  Really sorry ,so the best buy to the dealers.
I assume this means if you want service buy from the dealers.
« Reply #23 on: May 30, 2012, 05:21:58 AM »
I was just being a cheeky bu!*ar.
