Author Topic: Problems with charging 36v Frog Battery and Magic Pie  (Read 98927 times)
Offline marckorbin
Re: Problems with charging 36v Frog Battery and Magic Pie
« Reply #15 on: July 31, 2011, 09:17:26 PM »
It's been almost a week and I haven't heard a reply back from anyone.
Would it be better to go through PayPal and request a refund through them? So I can reorder the charger through someone more reliable?
Offline Supatrike
« Reply #16 on: August 30, 2011, 06:16:18 AM »
Hey Mark,
I think I am having a similar problem, but I'm not sure it is the charger... what is the status of your situation?
Supatrike
« Reply #17 on: August 31, 2011, 01:04:45 PM »
I am just wondering if your battery is marked with the voltage as well. Are you sure its a 36 volt battery?
Offline Thaialien
Re: Charging voltages
« Reply #18 on: August 31, 2011, 01:09:40 PM »
The charging voltage for the standard Lithium Manganese packs are as follows:
Chargers for 48V packs are usually marked 54.6V
Chargers for 36V packs are usually marked 42V
Chargers for 24V packs are usually marked 29.4V
I seem to recall Gary mentioning that the LiFePO4 packs use the same chargers.
Hi Guys are these ouput voltages on chargers min ? or max ? or +/- % ? or are they subject to Magic ?
Thank You !
« Last Edit: August 31, 2011, 02:23:45 PM by Bikemad »
« Reply #19 on: August 31, 2011, 02:37:00 PM »
Are these ouput voltages on chargers min ? or max ? or +/- % ? or are they subject to Magic ?
The voltages stated are the pre-set maximum charge voltage, and I would expect the actual output to be within ±0.1V of the stated figures.
Offline Thaialien
« Reply #20 on: August 31, 2011, 04:26:32 PM »
Thanks for that !
I wonder how the one I got even from day 1 only went up to 53.8v  Ihmmmmm  :-\
John
« Reply #21 on: September 01, 2011, 05:37:34 AM »
Thanks for that !
John
Was it connected to a GM battery?
Offline Thaialien
« Reply #22 on: September 01, 2011, 01:32:16 PM »
Hi Mm and all !
at the time only to ouput of charger (RCA cut down centre pin ) plug ...OK ! may be something there ! but battery (GM 48v 12 A  only ever manged two thirds or the distance of SLA's 4 x12v 12 A .
( run on both batteris ) more wieght !... so they were only connected for emergency to go to ( jail do not collect 200 pounds )
 home directly . (Or Pedal ! )
(charged every night all batteries )(GM pack only lit two led's on GM thumb controller ...SLA's all)
Pedal 100 kgs ebike in tropics is really hard work !
Many thanks
John L
at the moment battery is back with dealer last week ( he had a few more sets there open up for problems ) same pack 48v 12amp ....Uhmmmmmm !
Offline Thaialien
« Reply #23 on: September 05, 2011, 12:08:09 PM »
Hi all
recieved email today from dealer !  some answer you back !
and the good news about 48v 12A battery pack dealer would like 385$ to change internals to 48v 8A....
What do any of you think about that (P.S. thats on promotion )
Might be cheaper to run it on DURACEL's
and I could just buy them as I go ! pop into shop .gas staition supermarket or even 7/11
Many thanks
John L
« Reply #24 on: September 21, 2011, 12:56:15 AM »
This may not actually be true. When receiving my first shipment of batteries that were lifepo4 and lithium I noticed the chargers looked identical but some of the charger boxes were marked LT for lifepo4. I asked china if there was any difference and they of course said "they are all the same, do not woory". Now recently they have told me they are different. It would seem the first answer was an aswer of convenience, not fact.
« Reply #25 on: September 21, 2011, 06:23:55 AM »
Hi all
Many thanks
John L
Why on earth do you want to change the battery from 12 to 8Ah? You will only have 20A max continuous output and 30A peak max let alone less range.
Perhaps you may be better off with Duracell after all
Offline Thaialien
« Reply #26 on: September 21, 2011, 11:57:03 AM »
Hi Monkeymagic and all
Well the GM dealer thinks it's a good idea ! to go from 12A to 8A  ::) as I purchased the pack from him .
Think I better try get dealer to send it to me back (but it might get lost now in the post )
maybe the service charge might be 385$ plus postage  ::)
This get as good as Garmin here got Offical Garmin to put new lithium batt in they broke the board no sound anymore and charge me 50$ and refused to repir (garmin is which country ) for the Privilege as they say now anything more than six months old is obsolete and not worth repairing.
John L
« Reply #27 on: September 21, 2011, 02:37:11 PM »
Surprisingly I find it extremely difficult to believe a dealer would suggest changing a 12Ah pack to an 8Ah, I won't even ask about what battery management is supposed to replace the original.
Plus the fact the 48v packs are tack bound by 3, it would be a complete mess if you wanted to do this.
Which dealer are you buying from? You seem to buy alot of broken stuff  ???
Offline Thaialien
« Reply #28 on: September 21, 2011, 04:08:12 PM »
well over 2 years one dealer
6 Hub motors 2 types
5 cruise controllers
1 x 48v 12 A battery pack
1 x charger for that battery
3 pedilacs
3 disc
3 disc brake calipers
2 sets brake levers
2 x cruise / light switches
2 x the other swich cruise on/off / horn
and I forget the rest !
not bad from private customer (Gary would have loved me )$$$$$$
look on GM website for s.e. asia distrubutor.
Seen many strange things with motors motor cable lenght from 2000mm to 450mm motors in alloy casings around two differnt ways....... I just think must be a couple of Guy's working from home subing out work to neighbours (have done bissiness with a few of them here order 500 units and they are ready after two evenings THATS TRUE OK)  before used to sell automotive LED's as one line,,,,
Street food here can be faster than MacDonnels lol lol
By the way waiting for 2 BLT 800"s .......and thats not Burgerking's Bacon Letuce and tomatoe"s
By the way (i see no comment's about Braking Controller {that means to me it }worked fine reliable)
John L
« Reply #29 on: September 23, 2011, 01:11:32 PM »
3 pedilacs
3 disc
2 sets brake levers
John L
Awesome John, thats fantastic. I don't think anyone can compete with your plethora of ebike hardware and somewhat unlimited amounts of $$$$$$$$. I tip my hat to you
