Author Topic: MP battery cable amp rating  (Read 77021 times)
Re: MP battery cable amp rating
« Reply #15 on: February 22, 2011, 07:45:33 PM »
Alan, thanks for emailing the zipped program from Cornelius, but as usual I ask questions but don't understand the answers :-[    I don't quite understand what to punch into the calculator
Offline Cornelius
  • Grimstad, Norway
« Reply #16 on: February 22, 2011, 08:03:00 PM »
Depends on what you want to find out. :)
On the first tab, you'll punch in how many amp that would go through your cable; how long the cable are, one way ( the program calculates for 2 wires.), and how many volts you will accept as loss in the cable.
(Do not try 0 volts loss, because that's an impossibility. ;) For example, a short run of 1 metres, try 0.2V; then try 0.1V and see the difference of minimum cable area...)
The result will be the minimum size of recommended cable size, and how much loss in Watts in the cable at given Amps.
On the second tab you can calculate cable loss for your existing cables. Enter current Voltage, size of the cable, length of the cable (one way; the program calculates for a 2wire cable), and how much Amps that's running through the cable.
The result are given in Volts lost, Volts at target; Watts through the cable, and loss in the cable in Watts.
That should be it. :)
Edit:
You don't have to enter numbers on both tabs; only on the tab you're interested in the result. :)
« Last Edit: February 22, 2011, 08:07:37 PM by Cornelius »
« Reply #17 on: February 22, 2011, 10:32:16 PM »
so let me get this right.....
you guys don't drink a litre of wine before modding your bike, and 1.5 litres before riding it ???
Now whilst this clearly makes sense on the handling issues ive been having, im still not sure I see the point. I mean, the streetlights in my mind have a startrek theme tune....is it time to talk to the nice doctor ?
you know I jest...dont you ??? lol
« Reply #18 on: February 23, 2011, 12:25:28 AM »
No offence gingey but wine is a womens drink here in the land of OZ
BEER!!! 100%
« Reply #19 on: February 23, 2011, 08:34:04 AM »
BEER!!! 100%
If you can say the sentence above without slurring after 2 pints of his home made Honey wine, then you truely have a bigger problem than me  :D.  I would happily pay a hansom sum of money for what he cooks up in his laboratory. If only you could harness it in a battery...... :o
Offline Cornelius
  • Grimstad, Norway
« Reply #20 on: February 23, 2011, 08:56:00 AM »
Plenty of energy in beer and wine... ;) Distill it and put the alcohol in a fuelcell... ;D
« Reply #21 on: February 23, 2011, 09:29:12 AM »
True that honey wine sounds a treat, and well, if you make it yourself bonus !!
I think I would only be good at making rat poison haha
« Reply #22 on: February 24, 2011, 01:51:30 AM »
BEER!!! 100%
lol, now now, settle down!! I have to aggree though. It is very european to drink wine. In Canada the woman drink the wine. I think we are going to have to start a booze section in the forum. It seems like its taking over. Beer and Bikes? Booze and Bikes? lol
« Reply #23 on: February 24, 2011, 09:39:21 AM »
i do homebrew beer and lager too :)
heres one for you euro regs guys :)
http://www.stormthecastle.com/mead/fast-cheap-mead-making.htm
benefit of homebrew is you can select your alcohol level......
Offline Cornelius
  • Grimstad, Norway
« Reply #24 on: February 24, 2011, 10:37:52 AM »
...... and the taste; which usually are better than standard commercial beer... ;)
I too brew at home, mosty from kits; both beer and wine. :)
« Reply #25 on: February 24, 2011, 12:25:17 PM »
I'm getting thirsty.  I must make me some Mead!
« Reply #26 on: February 24, 2011, 06:36:02 PM »
Here's a useful link for this theme:
http://www.accesscomms.com.au/reference/awg.htm
The cable i've decided to use to extend my pie power cable comes out about 14 AWG, so about the same as my GM power cable. Thanks for all the info
