Author Topic: Joining two PIE power cables to one battery connector  (Read 83909 times)
Re: Joining two PIE power cables to one battery connector
« Reply #15 on: January 14, 2011, 08:39:57 AM »
Ohhh poor Monkey nobody reads his posts lol
60W is enough. I use a 'automotive' one that's 80W with a big splade tip. It was about $20AUD (so around £20 hehe)
If you already have a 60W use that, as if you ever have to solder onto a PCB (the BMS or controller for example) then you don't want something TOO hot.
Really you are just doing the wires, so even a blowtorch will suffice champ
MM
« Reply #16 on: January 14, 2011, 02:48:43 PM »
Thanks for taking pictures, I need visuals :D
makes complete sense.  I will try soldering on a new connector first, as it is cheaper to buy one of these than to buy a pack of marrette connectors.   When/if it all goes wrong I will use the marrette as plan B  ;D
I will get there, never mind how slowly!
The pictures are no problem. I just wanted to show you how simple the wiring can be and that you may be overthinking it.
« Reply #17 on: January 14, 2011, 04:44:22 PM »
Ive used a 48V before, just takes longer
Monkey, how far down the line did you go with the thicker wiring, all the way into the pie or just to the connector ?
Regards
« Reply #18 on: January 14, 2011, 05:59:58 PM »
MM
i did read,,   I was just checking I had read it correctly! ;)
« Reply #19 on: January 14, 2011, 06:24:03 PM »
Ginge,
got the Anderson,   I think that 'RS Components' is going to come in handy. just ten minutes from my work place. ;D
« Reply #20 on: January 14, 2011, 07:58:29 PM »
do I need any special kind of solder or will any cheap solder do.  I've heard about rosin being used as an ingrediant in solder, do I really need this in the alloy mix?
« Reply #21 on: January 14, 2011, 09:28:06 PM »
To be honest I havent used it....not to any detrimental effect...have pulled 38 amps through these connections with both pies and no problems so far......im sure there is a reason, but don't know it yet
RS components are pretty handy I must admit, just getting ready for my 5v relay install, to turn off one pie and enable disable the cycle analyst limiting.....might use another relay for throttle / PAS control on or off...........too much time, too many children, ....shed beer time ;)
Re: Soldering connectors
« Reply #22 on: January 15, 2011, 01:09:46 AM »
Andrew, I always use "flux-core" solder for electrical work and non fluxed solder for plumbing joints.
Flux-core solder already has the flux (which is needed to reduce oxidisation and help produce a much better joint) contained within the solder itself.
Most flux-core solders contain a rosin based flux, making them much more suitable for electrical work than the acid based fluxes which can cause big problems if the surplus flux is not removed thoroughly.
The alternative is to use a separate flux paste which is applied to the area to be joined prior to using non fluxed solder.
If you buy your solder from an electrical supplier, the chances are it will be flux core solder, but if you buy it from a plumbing supplier, it's more likely to be non fluxed solder.
Hope this helps.
« Reply #23 on: January 15, 2011, 08:23:46 AM »
thanks Alan, yep, makes sense :)
