Author Topic: Magic Pie loses all power under load at low speed  (Read 195650 times)
Re: Magic Pie loses all power under load at low speed
« Reply #45 on: January 19, 2011, 08:04:18 AM »
Hey Andrew
You have 2 spare controllers??? Awesome
What PCB's are they? (MX-318/319?)
How did you get those!! Sneaky
Don't even think about changing it unless its broken... And if a controller does fail, never throw it out as you can near guarantee it's just a couple of FET's on the board.
From memory, 1 forum member modded the internal controller running it external before changing it to an infineon. All other attempts to modify the board have seemed to fail.
I'm leaving mine alone ;)
The other night I fixed a MX-318 PCB (the one with the shunt mounted on side1 of PCB) before it had 5 beeps, I replaced the FETS and now it doesn't beep even without throttle connected - but plugging in a throttle it works!! (not sure for how long though..)
You can definitely 100% purchase an internal controller from GM - I paid $60USD via EMS over a year ago now and was sent a pack of circlips, MX-318 PCB (current at the time), new power wire (battery anderson connector), full pack of spare quick disconnectors + new controller to DIN socket harness
Not sure if it's the same price now, or what you get - but I'm sure it's available.
So how did you come across these controllers Drewmeister ??
:D
« Reply #46 on: January 19, 2011, 11:02:09 AM »
MM, Andrew didn't say they were spare controllers, he's referring to the ones already fitted inside each of his Pies! ;D
« Reply #47 on: January 19, 2011, 11:31:25 AM »
LOL I was wondering if people ebay those or something!
Thanks for pointing that out :D
Well keep them snug Andrew :)
« Reply #48 on: January 21, 2011, 04:47:33 PM »
Im afraid to say that Alan is correct.  No spare i/c's here  :(
« Reply #49 on: January 21, 2011, 05:40:09 PM »
Ohhh well that would have been nice :)
Still, it let me spill my story of replacing the blown fets in the other controller.
I have a couple of non-GM hub motors here I may try and test it on. I'll make a spiffy cooled controller box for it before I do any testing.
So is your rim true yet Andrew !?
:D
« Reply #50 on: January 21, 2011, 07:16:12 PM »
:D
Yeah,,    where you been?(or am I missing the humour :-\).........  I've been riding on the crest of a dual pie wave for the last 3 days. Rim arrived from China on monday with a set of new spokes, it was taken to a bike shop (i hate bike shops by the way) and they relaced it. same day I set it up and plugged it all in, and off I went. No regen or cruise, just me the pies and hydraulic brakes. I will try and take lots of photos this weekend and post up all the mods i've done to my bike since starting out on this E-Bike adventure ;D
Andrew :)
« Last Edit: January 21, 2011, 07:26:43 PM by Andrew »
« Reply #51 on: January 22, 2011, 02:42:01 AM »
Andrew :)
Certainly seems like you are enjoying it. Doesn't it snow where you are?
« Reply #52 on: January 22, 2011, 09:40:43 AM »
the snow has thawed out for the present. Being in the South of the UK and being on the coast, snow is more of an event than a permanent fixture during winter. Anything that breaks up the monotony of rain and darkness is usually welcome.  At present it's just crispy cold and sunny,, which is a blessing.
« Reply #53 on: January 26, 2011, 09:49:29 PM »
ordered a spare controller myself, for external ( thanks gary,  pie is fab by the way ) , im sure with dual pies, either replacement or parts, one will come in handy to have on hand sooner or later.....
« Reply #54 on: January 27, 2011, 02:41:04 PM »
Glad to hear the pies are running well. Beware of the regen though. I noticed some high spikes from regen when I was testing it at full on both pies.
« Reply #55 on: January 29, 2011, 08:04:59 PM »
Cheers for all the help Gary
To be honest I have disabled the regen on both wheels...my area is hilly and when I tested on 50% regen on a single wheel, I was pumping up to 25 amps regen peak......im not risking the controllers , got some good disc brakes :)......
Anyone had a response from GM on the use of USB cable limiting the controllers to 15 amps ish ?
regards
« Reply #56 on: January 29, 2011, 08:46:13 PM »
like you Ginge i'm not risking using regen.  My bike is sweet just using hydraulic disc brakes. From what i've read,  and how I ride, I just don't need the regen, and with internal controllers i'm not about to take any cahnces. I have regen/cruise buttons connected to one pie at prresent, but I think I may strip it out of the equation all together
« Reply #57 on: January 29, 2011, 11:13:42 PM »
Whats the question? Did I miss something?
