Author Topic: Battery Charging or not charging? That is the question.  (Read 115146 times)
Re: Battery Charging or not charging? That is the question.
« Reply #15 on: July 31, 2010, 04:15:13 PM »
Decide your relay and post what it is and I can tell you the value resistors you need.
Thank you for the information and offers. The solar panel rig is on my mental drawing board at the moment and the original plan had not taken into account GM's own solar set up. I will keep in mind your offer of assistance when I get around to financing that project. The Li-ion battery pack seems to require some specialised treatment and so I am treading carefully. cheers
Yes there are some concerns about the charging type being used on Li-on batteries.  The electrolyte isnt so aqueous as SLA's so I doubt to much problems can come from this.  EG acid boiling off at lower current at 15v.
If you already have the panels the relay charger is cheap.
$5 relay
$2.50 resistor pot
25c resistor.
I do a few more tricks like use a regulator to give me a standby charge voltage on one of the relay switch points and a reset switch. Among other things I could make it vibration proof by using a fet or transistor threshold to the switch coil.  So if the relay gets a bump close to switching voltages it doesnt shut off the full charge voltage.
Ive seen folks use a light bulb a diode an AC wall socket supply feeding 120v through a light bulb and using the constant current from the series feed into a small gel battery.
Like this
Disclaimer: If you do this to your GM battery and it dies LOL at you.
Cost you a few dollars at most.
It looks bloody shocking doesn't it :o.  And it would be if you didnt turn it off. or you kill yourself.  So don't do it at home kiddies. LOL But it proves that you can charge a battery off anything if you want.
But you just need the watts and volts here.
Say your wall socket is 220v and you bulb is 100watts. 100/220=454ma  This will allow 454 ma into the battery.  So use 5 bulbs and you have 2.2 amps. People with 110v AC outlet are more lucky.  I would put in a cap at least to filter out the the ripples.
You just need a switch like my relay to turn it off at the right volts.  The lights will go brighter as the battery charges up.  LOL youre looking at 420 watts down the drain when the battery fill up.  I think the Li-ion batts would use a little more watts in the beginning stages.
I could do some tricks to make it better.
It does work and I can show you if you want.
« Last Edit: July 31, 2010, 04:21:53 PM by 317537 »
jensenff
  • Guest
« Reply #16 on: July 31, 2010, 07:51:03 PM »
Hi
I've a similar or perhaps equal problem with my charger.  It is of the same type, all new.  First time use --> OK.  After , it will not start.  My charger just 'blips'  green and clicks when connected to the battery.  My battery voltage is not as low as Onetom2, it is 37V.  Output of charger is variating, 0V - abt 10V for every 'blip'.
I've also mailed Tom;  No reply yet, I'll wait a little...
BR Stein
« Last Edit: July 31, 2010, 09:26:23 PM by jensenff »
« Reply #17 on: August 01, 2010, 01:29:43 AM »
These are pretty cool
You can use these in series to get 48v if they have an isolation transformer like above.  Then use a LM338 for constant voltage and a shunt and resistor to regulate constant current and a relay switch to cut the bulk charge.
Until GM responds to your emails, I will keep posting other solutions.  I wont post other brands in the GM forums but there are other alternatives we can make to keep us on the road..
I used a 15v 6 amp transformer and made an old school voltage multiplyer that could do 2.2 amps to a 48v SLA pack.  The current drops out as the voltage rises to 60v to 1 amp.
The half wave seemed to fail with polarized caps but the full wave above worked well with big electrolytic caps and lasted for a year until I defunct it on a 36v pack.  It drew too much current from the transformer.
The below is a full wave voltage multiplier.
This really charged my SLA's better than anything I have used to date.  at 15v per SLA I would have the voltages at rest sitting at 13.6 comapered to 13.2v Strnage beahavior and I thought the batteries were not liking this.  But the bike flew like a hawk every day, up to three times a day, for 6 mths until the SLA finally lost capacity.
jensenff
  • Guest
« Reply #18 on: August 01, 2010, 10:08:22 AM »
I think I will have to try to make me a charger...  I've ordered a new one from GM.  But since two already has failed, I am not shure if it will last.
As I understand, the principle is to be able to limit current and also be able to limit voltage?  If I limit voltage to 42 volt, it will be safe?
BR
Stein
« Reply #19 on: August 01, 2010, 02:45:39 PM »
BR
Stein
What you need to understand is why your chargers are failing before you can pass go.
Yes.  But it would be good to have a shut off and maybe, good to bypass that shut off if you want to gain manual charge absorption at 42v..
Current limiting is very easy.  Either use a shunt
Or this for precision limitation.
The math is very easy.  1.25v/AMPS require = resistor needed.
If you want 2.5 amps
1.25/2.5 amps = .5ohms 5 watt resistor for anything up to 3 amps.
An easy calculator is handy.
http://www.reuk.co.uk/LM317-Current-Calculator.htm
This Lm338 chip is identical to the lm317t but it can handle 5 amps.
You cant have anymore than 50 watts appear over the package with no cooling. To be safe use a  heat sink.
If you regulate the input voltage at 42v with a pack as low as 24v will produce 45watts at 2.5 amps.
As the battery charges the watts will dissipate.
here is the CV vesrion of this chip.  It is adjustable.
Here I drew up what an CC CV linear reg auto switching bulk mode/standby mode charger circuit could look like.  I believe it would work with some tweaking.
I could put a led light indicator in there.  And maybe a switcher in the place of the linear regulator.
There is easier ways to do up a reliable charger that wont break your brains.  Im just bored and wanted to practice some stuff.
« Last Edit: August 01, 2010, 02:50:53 PM by 317537 »
jensenff
  • Guest
« Reply #20 on: August 01, 2010, 04:18:52 PM »
Hi! ;D
Charger failing:  Agree , why they fail ?  Mine is same type as onetom2's charger.  Behave in the same way.
When the new charger arrive; How should the charger be connected?
I did use mine OK for one time only.  Cannot recall (100% sure) how I connected it / diconnected it.  But probably it died in this process...
Connect:
Alt 1. Charger to battery, then charger til 220V AC?
Alt.2  ehhh the other way, 220V first, then 42V to battey
Disconnect:
Any recommendation?  I will ask GM/tom these questions too...
Building:  Great ;D. I have LM317t's at hand.  I will search for a >42V dc - source. In the junk - bin I had lot of 24V DC trafo - supplies. I will continue charger-making also.
I'm currently back on SLA's , two 12V packs with a long work - history as UPS - batteries. Performance - wise it really ment back to 'pedal assist' compared to 36VLIION ;D
« Reply #21 on: August 02, 2010, 02:07:25 AM »
Hi! ;D
Connect:
Disconnect:
The Lm317t wont do the thermal dissipation like the LM338.
Power transformers are good as the current is transferred through magnetism.  They are not that good with heat.  But you can parallel the primary windings and series the secondary.
Those old heavy auto chargers are good.
I can use an arc welder and rectifier set up to get 48v adjustable from 30~120 amps. :o  LOL you need to shunt that one.  But you can pick up welders second hand for real cheap these days.
« Last Edit: August 02, 2010, 02:10:37 AM by 317537 »
« Reply #22 on: August 02, 2010, 05:28:10 AM »
I bought two of these from Dick Smith for $3.99 each I think.  Worth getting the bigger device IMO.
Some extra care with some diode protections, isolate the package output from the sink with thermal transfer matting, and use of thermal paste, and these current and voltage regultor things have been around me for quite some time now.  They seem to be rock sold and never let me down.
I'll take a guess but that big sink with a fan could do 8 amps or 300+ watts or which ever comes first, good of discharging and current limiting.  Id love to test it some day but I need them more than I care to admit.
Silly inefficient linear regulators ::).  Hmm maybe not so silly in hind sight,
« Last Edit: August 02, 2010, 05:38:16 AM by 317537 »
Offline Onetom2
« Reply #23 on: August 06, 2010, 03:56:47 AM »
Hmmm, I was sent some interesting information on the charging and life support for Lithium ion batteries, amazingly, from China. It explained how limited periods of charging with breaks of up to 2 hours improves the life expectancy of these batteries. I had no indication of what to expect when connecting a charger to a Lithium ion battery. I had no possible explanation for what transpired but was aware that @ 1.8 AH there wasn't likely to be any problems during a short top up charge, little did I realise how wrong I was. Armed with the new information I set up a timer which gave 30 minute bursts of the GM charger to the GM lithium 4 battery with a 2 hour break between each charge. Over night the charge cycle I had set on the timer had been in operation for 6 hours and only amounting to a total of about 2 hours normal charge time. Low and behold the usual one second pulsing continued at the beginning of each charge period as expected but this time when the pulsing stopped the red LED stayed on, which was reassuring, don't ask me why, its just was, ok? Occasionally the pulsing would start again and then stop with the LED remaining lit indicating it was doing its job. The voltage at the discharge end is now 38.2V So I think I have a little way more to go but will wait until I have run the bike again. There was quite a bit more information on the subject like not allowing the battery to discharge more than a few percent. There was other information especially in regard to electric cars in China. Has anyone come across a detailed instruction manual describing the rather irregular LED indicators or anything else on charging? I suppose like the rules about connecting any charger to any battery and mains is so widely known that assumptions are agreed and nobody bothers to write it down?
Re: Information on the charging and life support for Lithium ion batteries
« Reply #24 on: August 06, 2010, 11:54:36 AM »
Sounds very interesting, is this information in a format that you could upload so we can all see it?
Does it differentiate between the different types of lithium ion batteries?
(Lithium Polymer, Lithium Manganese and Lithium Iron Phosphate etc.)
I hope that's just while the battery is not being used, as I can't see anyone sticking to that suggestion.
It would be ridiculous having a 16Ah battery and not being allowed to use more than ~0.5Ah.
Glad to hear your battery is charging again, it will be interesting to see if the problem eases after a few cycles of the battery.
« Reply #25 on: August 06, 2010, 10:31:41 PM »
Actually, if you think about the voltage, then yes, discharging
more than a few percent is bad.
A 2.7 volt cell should not be discharged below 2.5 volts,
thats about 8%.
You can still discharge lower than that, but it shortens the
battery life.
« Reply #26 on: August 07, 2010, 06:18:22 PM »
thats about 8%.
battery life.
I once set my SLA charger up on a timer to charge every 15mins and off every 15 mins for 8 hours. Four hours on and four at rest in total.  When I woke up the next morning, All my batteries were fully charged, in balance and discharged in balance too.
I have some theory in the works.
I will post it when I can understand how to explain best, that the more voltage drop over each cell equates to less resistance due to charge storage/
With resistance, more resistance usually equals more voltage drop.
Inside the cell this is opposite.  Like a mirror.  Voltage drop from one cell to the other indicates charge state not internal resistances. This may allow me to understand why higher voltages to the pack don't charge batteries faster than current, yet I have observed that using a higher voltage seems to make cell voltages vary wider. This sounds like a bad thing, may be not.  As we observe that the smaller V drop on any cell indicates the lower charge state so to the wider voltage differences between cells may indicate better charging of the lower charged cells.   The actual charging voltage into the cell is higher the more variance you can achieve between cells with the nominal pack.
What I mean is that, if you put a 56v charger on a 48v pack it will charge fine if balanced, but if it isnt balanced, try putting 72v @ 1 amp on the pack and you will see larger voltage variances between low cells and high cells.  This can let the BMS work better as it can sense the larger voltage differences between a low charged cell and a full charged cell.
It must be rated under 80 watts so this allows time for the energy and BMS to work its job.. The pack must be cut at HVC at the rated pack voltage regardless of the 72v input voltages so no damage is done to any cell and one must watch the cell voltages like a hawk.
Other wise try the timer at bulk mode voltages as you will notice at the beginning of the charge the same anomalies I described above larger variances of cells voltages every time the timer charge kicks in.  The full cells will be higher and the low cells will be lower.
I am scared to tell people to put 80v on there packs as you know what could happen if it left on too long.  And just as scared suggesting the timer method I have used with my SLA's.
I just tell people to leave it on for days and hope the trickle will balance things out.
Edit:
Surface charge can have no time to be absorbed when the variances are so little and trip the charger off earlier.  Where as at higher voltages one will observe strange balance behavior not yet described or defined by anyone I have seen yet.
On the 48v SLA's I balanced with a zener shunt looked scary with a 72v input.  The fuller capacity would rise sharp and then emptier battery responded by picking up the charge potential. As the lowest charged battery was the highest resistance it had more voltage potential over the terminals.
After not too long the voltages would rise up like a Mexican wave along the batteries finding any missing capacity in the lower cells.
« Last Edit: August 07, 2010, 06:42:26 PM by 317537 »
Offline Onetom2
« Reply #27 on: August 09, 2010, 01:43:50 PM »
I'm sorry if this doesn't seem much I have left out the guys story about "electric bicycle lithium battery protection board"
and solar charge. These passages were translated by a friend in China and I have asked her for more. It was her input about the characteristics of smart chargers that influenced my idea. I asked Tom from GM for more information but have received nothing further regarding charger behaviour.
Based on the characteristics of lithium batteries, lithium batteries and maintenance techniques we summarized as follows:
1. Do not let the lithium battery power less than 3% (20% recommended start charging)
2. 1% lithium battery can become a "deep discharge" must avoid "deep discharge." As "deep discharge" directly affect the life of lithium batteries.
3. Long-term (more than 3 months) when not in use lithium batteries should be charged to 50% of the electricity saved
 Battery electric vehicles are now almost 95% of the lithium battery, the principle is the same, the battery electric vehicles and mobile phones are the same nature, only voltage and current difference between the size of it. . This is currently one of the words should all know. . So I ask you that again with the photoelectric charge of, your use of light electric vehicle battery is fully depleted you go? The batteries have to charge you 12 hours? Strange if it does not charge explosion. The correct way is to post full of tips, about 1 to 2 hours a buffer can be, this is the most authoritative methods. Lithium batteries and other power must not be exhausted. Otherwise, will be in trouble soon.
My burden is ignorance of the subject in its entirety. Conventional LA & SLA I understand basically but I am at sea in a thick fog without a paddle when it comes to these babies.  The information aired online in various papers by industry observers, suggests that most Lithium Ion Battery manufacture's design and develop their own individual charge management systems which means without any further offerings of data and problem solving I am stumped? Can't just go buy another battery charger off the shelf and I don't know anything about that 4amp charger someone mentioned? ???
« Reply #28 on: August 09, 2010, 06:17:51 PM »
If your charger still fails to work.
You may have to purchase another GM charger or get one on warranty.
This is the closest thing I found on ebay.  It is too high for the GM packs.
http://cgi.ebay.com.au/Electric-Scooter-Battery-Charger-48V-17-20AH-/360288483959?cmd=ViewItem&pt=UK_ConsumerElectronics_Batteries_SM&hash=item53e2ddfa77
with 48V, 17 - 20AH batteries * Input power: AC 220V, 50Hz * Output power: DC 56.5, 48V * Max input wattage: ?85W * Output current: DC 2.5A *
Your pack requires 54.6v.  The above charger has 56.5v.  So you need to modify it.  Easy done!
3 Schottkey diodes in series .62v drop =1.86v drop  on the charge line will fix the voltage down for this charger.
The part no, for the schottky is MBRF30H60CTG
Can be purchased here or else where.
http://au.mouser.com/ProductDetail/ON-Semiconductor/MBRF30H60CTG/?qs=sGAEpiMZZMtvcUztdGSumOtO%252bDV5KVJy5xaTawNqY7A%3d
Personally I would just get a handful of 3 amps diodes schottky and rectifiers  and mix and match and test the drop cautiously until I got 54.6v on the mark
« Last Edit: August 09, 2010, 06:19:30 PM by 317537 »
