Author Topic: Magic controller configurable parameters  (Read 61776 times)
Re: Magic controller configurable parameters
« Reply #15 on: July 08, 2010, 08:09:51 AM »
Actually by some calculation (was over a page long), on the fets caps and shunts I'm getting a 5 to 8 ratio.
So do not exceed the max amps by 40% over your continuous settings.  30% is safest for the bigger motors and for the smaller mini motor 40% is fine..
« Last Edit: July 08, 2010, 08:26:15 AM by 317537 »
Offline mrcarl
« Reply #16 on: July 08, 2010, 09:44:55 AM »
Hi Leslie,
Thanks for your excellent reply and for doing the math.  Also kudos to Alan for his info.  You guys are fantastic and really make this journey a lot easier for us newbies :)
Keep up the great work!
With gratitude,
Carl
« Reply #17 on: July 08, 2010, 10:00:55 AM »
True that.
Yes Alan is super.   ;)
We lub our moderator.  8)
To TOM
« Reply #18 on: July 09, 2010, 12:05:40 PM »
Please give me your email address,I will send it to you by email.
Hi Tom.  It is good to see you here in the forums. We all would like to see you more.
You have some good infornation to share. I understand english maybe hard for you, We can help.  I will suport TOM, and TOM will support me?
You give good advice about charging batteries in winter.
I add it here. I add more good advice, and advice of things not to do, to install and maintain GM motors.
If you are not using your bicycle, Do disconnect the battery connector, Do charge the battery at least once every two months and more often in winter.
In this thread here.
http://goldenmotor.com/SMF/index.php?topic=2303.0
If there is any bad technical things I write about GM motors, please tell me and I will change soon.
Thank you.
« Last Edit: July 09, 2010, 12:09:20 PM by 317537 »
