Author Topic: Need more power  (Read 32654 times)
Offline scott
Need more power
« on: October 25, 2009, 02:14:00 PM »
I’m currently running GM 48v 12 AH Lithium Iron Battery Pack .I’m looking to increase my range .
Any suggestions?
I live in Canada.It would be nice not to have to order from China.
Thanks Scott
Re: Need more power
« Reply #1 on: October 25, 2009, 02:29:53 PM »
Any suggestions?
Scott,
Replacing your current battery with a 48V 20Ah battery will give an additional 66% range.
Adding another battery, the same as you already have, in parallel will double your range.
Try your local Canadian GM Dealer: Click here
Or send a PM to Gary Salo (GM Canada)
« Last Edit: October 25, 2009, 06:41:40 PM by Bikemad »
Re: Need more power
« Reply #2 on: October 27, 2009, 11:44:40 PM »
Lol,
"Scotty! Give me more power!"
"If I gee er any more she'll burn up Cap'n."
Re: Need more power
« Reply #3 on: November 08, 2009, 02:19:25 AM »
Hi Scott
I’m thinking of two 48V 12AH batteries in parallel, I’m just not sure about the mounting. If I just stack them the weight maybe getting to high up. I'm thinking about mounting the plates and batteries on the sides of the rack but they will be unprotected if my bike falls over.
Canada is Going Green at www.GoldenMotor.CA
« Last Edit: November 08, 2009, 02:24:25 AM by GM Canada »
Re: Need more power
« Reply #4 on: November 12, 2009, 01:48:41 AM »
The 48V12AH battery is already in a protective case, but I would probably
put an aluminum skid plate over it just to protect it.
You could opt instead for the 48V20AH pack
http://goldenmotor.com/batterypack.htm
then pack that in a case like
http://shop.ebay.com/390115206045
New-Pelican-1400-Black-Case-W-PICK-N-PLUCK-Foam
